Fred Johnson the 3rd jr Posted September 13, 2011 Share Posted September 13, 2011 In the past I built some Twin Linked Autocannon arms out of IG Heavy Weapon Autocannons. I really like the bare gun look, with no shoulder pads / armor and I want to do that again. Thing is, because of Grey Knights, it seems like every freaking IG autocannon gun is sold out or costs a ridiculous amount of money. So what can I use / buy instead, to get the same bare arm, gun only type Rifleman look? The Forgeworld arms are obviously out of contention. Is there anything else out there? Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/ Share on other sites More sharing options...
breng77 Posted September 13, 2011 Share Posted September 13, 2011 I have seen a lot of people use are the autocannons from the Aegis Defense line kit. Now if you actually buy the kit it is rather expensive ($25 per dread) but you might be able to find those bitz. Or if you also need terrain this is a decent buy. Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2874507 Share on other sites More sharing options...
Elric the Silvercoat Posted September 13, 2011 Share Posted September 13, 2011 I have seen a lot of people use are the autocannons from the Aegis Defense line kit. Now if you actually buy the kit it is rather expensive ($25 per dread) but you might be able to find those bitz. Or if you also need terrain this is a decent buy. But remember that with one Aegis Defense line you will get both arms for the Rifleman Dread and you will get some barricades for terrian. Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2874555 Share on other sites More sharing options...
red_starrise Posted September 13, 2011 Share Posted September 13, 2011 Here's a WIP pic from a while back of my rifleman dread made from an AOBR dread & 2 predator lascannon sponsons & a predator TLLC turret gun: Â http://i184.photobucket.com/albums/x84/red_starrise/40K/Imperial%20Fists/CIMG4608.jpg http://i184.photobucket.com/albums/x84/red_starrise/40K/Imperial%20Fists/CIMG4566.jpg http://i184.photobucket.com/albums/x84/red_starrise/40K/Imperial%20Fists/CIMG4565.jpg Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2874692 Share on other sites More sharing options...
breng77 Posted September 13, 2011 Share Posted September 13, 2011 But remember that with one Aegis Defense line you will get both arms for the Rifleman Dread and you will get some barricades for terrian. Â Oh I am aware of that , but if you are doing say 6 dreads it adds up. Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2874784 Share on other sites More sharing options...
KhorneHunter57x Posted September 13, 2011 Share Posted September 13, 2011 Thing is, because of Grey Knights, it seems like every freaking IG autocannon gun is sold out or costs a ridiculous amount of money.Grey Knights, Codex Marines, and the fact that the IG Autocannon is both the best infantry weapon they have AND desirable for Hydras... I think your best bet would be to look at Heavy Bolters (IG, Razorback, Land Raider, Valkyrie/Vendetta, etc. I would personally use the Razorback ones as they have a left and right side) and find one that you like the look of the 'body' of the weapon and then remove the barrel and replace it with one made from plasticard tubing. If you get two different sizes of tubing where the inside diameter of one is the same as the outside diameter of the other, then you can slide sections of the larger over the main barrel to make it more detailed (so it is more than just a long tube, but looks like an Autocannon). Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2874837 Share on other sites More sharing options...
Fred Johnson the 3rd jr Posted September 14, 2011 Author Share Posted September 14, 2011 Thing is, because of Grey Knights, it seems like every freaking IG autocannon gun is sold out or costs a ridiculous amount of money.Grey Knights, Codex Marines, and the fact that the IG Autocannon is both the best infantry weapon they have AND desirable for Hydras... I think your best bet would be to look at Heavy Bolters (IG, Razorback, Land Raider, Valkyrie/Vendetta, etc. I would personally use the Razorback ones as they have a left and right side) and find one that you like the look of the 'body' of the weapon and then remove the barrel and replace it with one made from plasticard tubing. If you get two different sizes of tubing where the inside diameter of one is the same as the outside diameter of the other, then you can slide sections of the larger over the main barrel to make it more detailed (so it is more than just a long tube, but looks like an Autocannon).  That sounds like a lot of work, when my initial plan was to glue autocannons together! I did manage to find pre-made barrels, here: http://oldcrowmodels.co.uk/25turrets.htm  So perhaps skill-less me could slap those onto some bolter-ish thing.... Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2875677 Share on other sites More sharing options...
Jamafore Posted September 16, 2011 Share Posted September 16, 2011 Hmm. A couple of those turrets look like they would make nifty Razorback or Pred turrets. Or maybe see if I can't juryrig it on a Land Raider. Â Insert evil laugh here. :) Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2877038 Share on other sites More sharing options...
chromedog Posted September 16, 2011 Share Posted September 16, 2011 I picked up a few spare plastic dread weapon arms over the years. More than enough assault cannon and missile pod arms. Â One Robogear starter box gave me sufficient autocannon barrels for the task (for two sets of paired arms). Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2877111 Share on other sites More sharing options...
Jsmarriner Posted September 16, 2011 Share Posted September 16, 2011 Ok I guess Im just not as upto date on my codex readings and such, but where can I find the rules on this rifleman dread? I havent seent it before except on here. Is it a White Dwarf thing or what? Â Thanks Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2877230 Share on other sites More sharing options...
Brother Anvilus Posted September 16, 2011 Share Posted September 16, 2011 It's merely a name for a dreadnought with 2 times twinlinked autocannons.Comes from battletech or soemthing I believe? Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2877237 Share on other sites More sharing options...
breng77 Posted September 16, 2011 Share Posted September 16, 2011 A rifleman dread is simply a dreadnought with a twin liked autocannon on both arms. This is a configuration for standard dreads. The rifleman term is just the shorthand/slang term for that configuration. Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2877238 Share on other sites More sharing options...
Brother-Chaplain Kage Posted September 16, 2011 Share Posted September 16, 2011 Build your own autocannons out of brass or plastic tube/rod Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2877558 Share on other sites More sharing options...
chromedog Posted September 16, 2011 Share Posted September 16, 2011 It's merely a name for a dreadnought with 2 times twinlinked autocannons.Comes from battletech or soemthing I believe? Yeah, name comes from Battletech (except it had a combo of laser and autocannon in each arm). This one (the original 'borrowed' design from Macross) http://brianscache.com/unseen/tro-rifleman.jpg Link to comment https://bolterandchainsword.com/topic/238340-rifleman-dread-advice/#findComment-2877662 Share on other sites More sharing options...
