FW Dread Bodies and GW Arms
D-USA
Quick question, I am thinking about getting the Raven Guard Dread from FW, but I was wondering if the arms from the regular GW Dread can be used on it. I think that idealy I would just magnetize both dreads and all the arms between the two to give me more options if they are compatible.
Thanks
https://bolterandchainsword.com/topic/238464-fw-dread-bodies-and-gw-arms/
If you are magnetising you could prollie use them. The normal GW is slightly larger than the FW one IIRC. The design is also different too, in the sense that the mk4s have curved sloped pads, while the more mordern ones are just straight down.
I will probably give that a try then, unless somebody comes along on here and says that it will just look like junk.
I want to use the FW MK4 arms eventually, since I plan on having this dread be somewhat of a center piece (it just looks cool). I will probably order the torso and one of the scenic bases in one installment, using the GW arms with magnets, and then order the "proper" arms later.
  • 1 month later...
