bits needed
mcpolle
Theres a melta and plasmagun sprue from GW :yes: and missile launchers devastator box :P
The melta and plasma guns from gw are metal.
...and? What difference does that make?
Just saying....jeez ;)
Some people don't like to work with metal parts due to pinning and the easy of knocking the parts off.
Of note too, the weapons have a right hand sculpted on too.
https://bolterandchainsword.com/topic/238605-bits-needed/#findComment-2878552
Wasn't meaning to sound hostile, forte. Just wanted to understand the comment better...so I hope you won't take offense to this either, but...
Something that weighs next to nothing shouldn't need pinning.. and if your glue isn't keeping it on the model despite normal wear n'tear (short of it falling to the concrete floor and shattering utterly) then your glue likely isn't very good. Craptastic Krazy glue comes to mind. I've never had a problem with items falling off while using Zap-a-gap.
How you treat and store your models can also factor into this. If you toss everything into a shoebox versus in a foam carry case, you likely won't have good results.
And even though the right hand is sculpted on the piece, you're likely using a plastic arm, so just chop the hand off the arm.. unless you're wanting a left-handed model, which takes more conversion than just grabbing a plastic melta anyway.
https://bolterandchainsword.com/topic/238605-bits-needed/#findComment-2878579
