Marik Posted September 22, 2011 Share Posted September 22, 2011 For white primer do you think it would be better to error on the side of applying less or more when unsure if you have the right amount? Link to comment https://bolterandchainsword.com/topic/238874-primer-question/ Share on other sites More sharing options...
ninjaturtlethug Posted September 22, 2011 Share Posted September 22, 2011 Go for less, the first time I used white primer I used too much, thinking it wasn't covering well enough. When dry I had lost most of the details in the blobs of paint. Link to comment https://bolterandchainsword.com/topic/238874-primer-question/#findComment-2882011 Share on other sites More sharing options...
Firepower Posted September 22, 2011 Share Posted September 22, 2011 Well, I lean the opposite way, kind of. If there are still spots of gray showing, the alternative is to use white paint with a brush to fill in teh gaps. This, in my experience, proves to be an absolute pig. I always strive to fix gray patches with primer cans, though for the record I tend to use gator clip stands to hold the models by their bases and tilt them this way and that to hit those hard to reach places. Link to comment https://bolterandchainsword.com/topic/238874-primer-question/#findComment-2882015 Share on other sites More sharing options...
