Smendrik Posted September 23, 2011 Share Posted September 23, 2011 Is there a minimum distance a tank has to be moved to tank shock a unit before it hits on them? Link to comment Share on other sites More sharing options...
Elric the Silvercoat Posted September 23, 2011 Share Posted September 23, 2011 Is there a minimum distance a tank has to be moved to tank shock a unit before it hits on them? No you can tank shock someone right in front of your tank. But Ramming is different and you do want to move the most you can to get a higher Str to the ram. Link to comment Share on other sites More sharing options...
dswanick Posted September 23, 2011 Share Posted September 23, 2011 Is there a minimum distance a tank has to be moved to tank shock a unit before it hits on them? No you can tank shock someone right in front of your tank. But Ramming is different and you do want to move the most you can to get a higher Str to the ram. Actually, you must move as far as possible. There is no option to move less than your maximum amount. @OP : There is no minimum to a Tank shock. Link to comment Share on other sites More sharing options...
Smendrik Posted September 23, 2011 Author Share Posted September 23, 2011 So, if an enemy unit engages my tank in close combat and they don't immobilize it, i can tank shock them in my turn, have i got this right? Link to comment Share on other sites More sharing options...
Elric the Silvercoat Posted September 23, 2011 Share Posted September 23, 2011 So, if an enemy unit engages my tank in close combat and they don't immobilize it, i can tank shock them in my turn, have i got this right? yes Link to comment Share on other sites More sharing options...
Smendrik Posted September 23, 2011 Author Share Posted September 23, 2011 Thanks a lot! Link to comment Share on other sites More sharing options...
dswanick Posted September 23, 2011 Share Posted September 23, 2011 Just remember, you must yell "All ahead full!" after declaring the Tank Shock (and "Ramming speed!" if you intend to ram) or it automatically fails. Link to comment Share on other sites More sharing options...
Elric the Silvercoat Posted September 23, 2011 Share Posted September 23, 2011 Just remember, you must yell "All ahead full!" after declaring the Tank Shock (and "Ramming speed!" if you intend to ram) or it automatically fails. :D Or you can yell "For the Emperor" if your a Loyalist or "For the Chaos Gods" if your a traitor and it will auto kill or pen and you get a 1++ save to stop your vehicle from getting hit. Kidding! Link to comment Share on other sites More sharing options...
Sgt. Tiberus Satio Posted September 23, 2011 Share Posted September 23, 2011 Just remember, you must yell "All ahead full!" after declaring the Tank Shock (and "Ramming speed!" if you intend to ram) or it automatically fails. :D And sig'd..that actually made me laugh. Link to comment Share on other sites More sharing options...
awfulawful Posted September 23, 2011 Share Posted September 23, 2011 Just remember, you must yell "All ahead full!" after declaring the Tank Shock (and "Ramming speed!" if you intend to ram) or it automatically fails. :) I knew the "Ramming speed!" rule, but not the "All ahead full!" one. That explains a lot of failed tank shocks. Link to comment Share on other sites More sharing options...
