fatbudda319 Posted September 23, 2011 Share Posted September 23, 2011 I'm planning a conversion for my Marshall and was wondering if any one could recommend any UK Bitz sites. I've tried a few but none of them seem to have the bits I require. Heres a list of the parts I require, if any one can help me out it would be greatly appreciated: SM Command Squad Company Champion Shoulder Pads SM Command Squad Company Champion Torso Bit SM Commander Iron Halo Bit Warhammer Bit SM Commander Eagle Backpack Bit SM Commander Heraldry Shoulder Pad Bit SM Commander Purity Seal Legs x1 Bit Grey Knights Helmet Heads x5 Bits Black Templar BP & CCW Set x6 Bits SM Tactical Squad Torso Back x1 Bit Thanks again. Link to comment https://bolterandchainsword.com/topic/238998-bitz-buying/ Share on other sites More sharing options...
Lestat Posted September 23, 2011 Share Posted September 23, 2011 Try bitzbox - they are normally pretty good (better then bitz&kits anyway who I've had several problems with in the past) Here's a link: http://www.bitzbox.co.uk/ Or you could try various shops on ebay. Link to comment https://bolterandchainsword.com/topic/238998-bitz-buying/#findComment-2883714 Share on other sites More sharing options...
Grotsmasha Posted September 23, 2011 Share Posted September 23, 2011 I always use Black Dagger Games, prices and post speed and availability are excellent. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/238998-bitz-buying/#findComment-2883736 Share on other sites More sharing options...
fatbudda319 Posted September 23, 2011 Author Share Posted September 23, 2011 Cheers for the replys, was hoping to get it from the UK so hopefully the postage dosnt end up costing an arm and a leg. Had a look at the bitzbox but they dont have the bits I need in I'll have to keep popping back to it. Cheers, James Link to comment https://bolterandchainsword.com/topic/238998-bitz-buying/#findComment-2883748 Share on other sites More sharing options...
Grotsmasha Posted September 23, 2011 Share Posted September 23, 2011 Blackdagger doesn't add up the postage, they combine on bits, I usually pay less than $10AU postage for as many as 30 AOBR termies, on the sprue. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/238998-bitz-buying/#findComment-2883775 Share on other sites More sharing options...
fatbudda319 Posted September 24, 2011 Author Share Posted September 24, 2011 hmm.. interesting may have to give them a look then thanks Link to comment https://bolterandchainsword.com/topic/238998-bitz-buying/#findComment-2883985 Share on other sites More sharing options...
Brother_Fatiswon Posted September 24, 2011 Share Posted September 24, 2011 I'm planning a conversion for my Marshall and was wondering if any one could recommend any UK Bitz sites. I've tried a few but none of them seem to have the bits I require. Heres a list of the parts I require, if any one can help me out it would be greatly appreciated: SM Command Squad Company Champion Shoulder Pads SM Command Squad Company Champion Torso Bit SM Commander Iron Halo Bit Warhammer Bit SM Commander Eagle Backpack Bit SM Commander Heraldry Shoulder Pad Bit SM Commander Purity Seal Legs x1 Bit Grey Knights Helmet Heads x5 Bits Black Templar BP & CCW Set x6 Bits SM Tactical Squad Torso Back x1 Bit Thanks again. I have to second and third, both black dagger and bitzbox.. those are the two that i use the most: black dagger has better prices, but it seems bitzbox has more of the pieces that i look for: good new for you is that bitzbox does re stock the commader and command squad boxes fairly often: you can sign up and have them email you when they are in stock. and on the other foot: i would say that if you are willing to PAY the COST, then take a look at theWarStore (they cut bits to order) but they, IMHO, want to much for both the bits themselves and shipping+handling. As an example: i was looking at some black orc (WFB) helms and for like 5 bits, they wanted like $6+s/h Link to comment https://bolterandchainsword.com/topic/238998-bitz-buying/#findComment-2883997 Share on other sites More sharing options...
