Need help from my brothers
Arez
I've got some minis that need to be put together
the list is:
1 tactical squad-10 minis
1 chaos squad-8
25 SM.
i was thinking this:
15 "Wulfen" (using Blood Claw stats and rules)
2 ML Long Fangs
1 heavy bolter Long Fang
what should the other troops be and their load outs?
I'm taking all suggestions
https://bolterandchainsword.com/topic/239274-need-help-from-my-brothers/
What else do you have? What else do you need?
If you can answer these two questions, a plan should begin to form. Also, no such thing as too many GH's.
What i have so far:
10 PA WG(accidently made them.I was going to do a few GH a few BC and a couple WG but i gave them WG weapons :huh: )
5 WG termies
1 metal wolf guard(the one that you can get form GW that has a wolf head helmet)
1 RP conversion
11 fen wolves
1 predator(magnetized so it can be pred or rhino)
What i have but is not done
another predator kit ( going to be magnatized)
iron priest
lukas
2 servitors
2 ammo runts(going to be servitors)
razor back weapons my dad gave me
actualy, there is: 307 grey hunters.
what?
if that's what you have, make the others 25 grey hunters.
btw: 307 grey hunters is one too many.
6 packs with flamer (10 R&F, in case you just want to field a mass of bodies without upgrades, 2 flamers per packmarking, a plasmapistol per packmarking, a wolfstandard per packmarking, a MotW per packmarking, a powerfist per packmarking and a powerweapon per packmarking.)
same for meltasquads
same for plasmasquads :huh: 306 models
nonsense! there's always apocalypse! besides, a great company consisting only of 6 packs of 10 seems way too small in my opinion!
What i have so far:
5 WG termies
1 RP conversion
11 fen wolves
iron priest
lukas
2 servitors
what?
What Blacksad said.
To the Greenhorn:
- 8, 9, or 10 man GH's packs are going to be best. If you build 18 -> 20 GH's base, and use the other five to seven for PW, MG, PG, and Flamer weapons.
- Do you have your full list of HQ's that you would like? One SW PA model made with the Wolf Skull Torso, Wolf Pelt legs, Wolf Skull Backpack, the Wolf head helm, a BP right arm and the PW left arm may lead to a great WP conversion.
- There's a Runic Armor Rune Priest model out there, not sure if it's Finecast now or not, but it's worth it if you need more.
To the Greenhorn:
I used the Wolf pack that i had.That is what the WG are made of.
I was thinking of making a Ragnar counts as to lead the BC(my dad says that Ragnar is a good leader for assaulting BC)
Are you talking about the Termie RP?if so I dont like that model
Are Rune priests good at leading GH?If so i could make some of those.
I have 2 flamers 1 melta and what ever came in the Wolf pack for plasma.
Oh! just remembered this:what should i load my LF squad leader with?
And for the HQ:Im getting a Chaos Terminator Lord and going to convert him into my Logan count as.
To the Greenhorn:
A Ragnar counts-as has been done before, search for it if your searchfu is good enough. I'll also take a stab at that and see what I can come up with.
No, actually: it's a PA model, with a PP and a Power Axe. It's a very nicely done model, for it's time.
They can be, depending upon the powers chosen. I tend to use WP more often than not, so that's not always ideal, but it can make the enemy cringe when a WP + GH's hits their lines.
Maybe consider the SW Sprue special order from GW? It gets you a Meltagun, 2 Power Weapons and some useful Wolfy bits.
LF leader is very points dependent, and what WG if any you're putting with them. I sometimes just use a barebones model, as he's the first wound to go, if the squad takes any hits I can place on him. If anything, maybe a PW at most? Since the Pack Leader is the cheapest member of his pack, and the first that should go, keeping the angry heavy weapons of Fenris firing in his absence, he should have little if anything. Also, a WGPL would be quite nice, outside of Termy armor they can be great as another free wound. Our Long Fangs get up to five heavy weapons, but lack the spare Marines to keep from losing weapons due to wounds and failed saves.
I was just going to make a wolfed out model that has equipment like Ragnar.And thanks
PA RP I dont like either
My RP i have now I "converted" from Coteaz
Powers I've chosen is Jaws,Thunderclap and lightning.
Ya I was thinking about that.I could use the wolf pelt torso on it to make another RP.And (if this is against the forum rules i'll take it off) I was thinking on makeing a mold of the Wolf head back pack and giving them to my army.
I like the LF leader cause of the split fire.It comes in handy.Maybe just give him a flamer so he not a bigger point sink?
better off then with a plasmagun perhaps? if they're going to assault you anyway, might aswell press out a rapidfiring plasmagun and your heavy weapons on him, then counterattack, and hope for the best :)
Ok.
Hm i can just take that from my done WG unit :P ;)
