GK : Modeling questions & 3 Army list need finishing
Hi!
As the title say I need your help to finish 3 army list, and more important for me, I need some modeling advises (thats why Ipost here and not in the subforum armylist)!!!
So let’s begin by my modeling questions :
I need to make 14 Acolites with Storm-Bolter & 3 Crusaders. More-over I want to use some elysean heads I’ve already got on the SB ones. So my question are :
-How would the Elysian heads fit on SM Scout’s bodies ?
-What would you use : SM Scouts or Cadian Troops ? And Why ?
-What arms/peice would you use to make the crusader Storm Shield ?
Now Regarding the 3 army lists :
I’ve been collecting Ordo Maleus minis since roughly 15 years, and THOSE LISTE ARE MADE IN ORDER TO USE A MAXIMUN OF THE MINIS I’VE GOT, not in order to be competitive.
So EXEPT FOR THE THIRD LIST where I haven’t build the 14 Acolites with Storm-Bolter & 3 Crusaders mentioned above, I DONT WHANT ANY CHANGE IN MY UNITS.
WHAT I NEED IS ADVISE IN HOW TO SPEND THE POINTS I’VE GOT LEFT !
So here is the first one :
HQ :
-GM (Psycanon & NFH, both Master Crafted, Blind & Rad Grenade) : 255pts………. Goes w/ the GKT
-Archivist (NFS & 4 power) : 205pts…………goes w/ the GKT
Elites :
-GK Techmarine (Storm Bolter, Blind & Rad Grenade, 3 Servo-skulls) : 117pts……… Goes w/ the 5 PAGK w/out the Psy C
-9 GK Purificator (4 PsyC, 4 NFH, 1 DH) & 1 Justicar (DH), Dedicated Rhino : 338pts………….. A Combat Squad w/ 2 Psy C goes in the Rhino
Troops :
-9 PAGK (2 PsyC) & 1 Justicar (DH), Dedicated Rhino : 270pts……. Combat Squad w/ the 2 Psy C goes in the Rhino
-4 GKT (PsyC & NFS, 3 NFH) & Justicar (DH) : 225pts
Fast Attack :
-9 GK IS (2 Psy C, 1 DH, Psy-Munition) & Justicar (DH) : 300pts…… Each Combat Squad follow 1 Rhino
Heavy Support :
-Psyfle-Dread : 135pts
……Both dread, the TechGK with the PAGK Combat Squad & the GKP Combat Squad Protect my base
Total : 1980pts ! So what should I do whith the 20pts left ?
On to the second one :
HQ :
-Draigo : 275pts….. Goes w/ the GKT
-Archivist (4 power) : 170pts…… Goes w/ the GKT
Troops :
-10 Paladins (4 Psy C, 4 DH, 4 NFH, 2 NFW) : 630pts………… Combat Squad
-4 GKT (Psy C & DH, 3 NFH), Justicar Thawn : 300pts
Fast Attack :
-9 GK IS (2 Incinerators, 1 DH) & Justicar (1DH) : 320pts……….2 Combat Squad w/ 1 Inci & 1DH each, but both will follow the Dread Knight as fast as possible into the enemy lines
Heavy Support :
-Dreadknight (Teleporter, NGS, Heavy-Incinerator) : 260pts
Total : 1955pts ! Still 45 pts to play !
And finally the third one :
HQ :
-Coteaz : 100pts……….Join the Purificator & the Dread in the Storm raven
-OX Inquisitor (Conversion beamer, Power sword, 3 servo skulls) : 89pts………join the Servitors
Elites :
-Vindicare : 145pts
-GK Techmarine (SB,Rad & Blind, 3 Servo-Skulls) : 117pts………. Join the 3 DCA, 3 Arcos, 3 Crusaders & the 2 Aco w/ melta in the LRR
-9 GK Purificator (1 Incinerator, 8 NFH) & Justicar (NFH) : 258pts
Troops :
-3 DCA, 3 Arcos, 3 Crusaders & 2 Aco w/ Melta Gun : 163
-2 HB Servitors, 1 HP Servitors, 2 Jokaero, 1 Aco w/ Plasma gun, 1 Aco w/ Bolter & 5 aco w/SB : 164pts
-3 Aco w/Melta Gun, 3 Crusaders, 6 Aco w/ SB & Chimera (2HB) : 184pts
-6 Psyker, 3 Aco w/ SB & Chimera (2HB) : 136pts
Fast Attack :
-Strorm Raven (Heavy Armour) : 220pts
Heavy Support :
-LRR (Psy Munition, Psy Combutible, Heavy Armour & Multi-Melta) : 290pts
-Dread (Multi-Melta & Heavy Armour) : 130 pts
Total : 1996pts. So just 4 pts left, BUT here the Aco w/SB are not build nor buy yet. So this list may still see some change if you provide good input !!!
Sorry if this post was a bit long but I wanted to put the 3 list together, because there is another thing you could suggest : it’s to exchange model from one list to put into an other one. Just keep in mind that all list s hould be 2000pts in the end, and all models must employed : It took me YEARS to collect, assemble and PAINT them, so I want to play with ALL my toys !!!
Thanks in advance !
I will answer this. Not well FW stuff tends to be a bit more in proper scale for a human body then GW models and the Elysian heads will look small in comparison.
For me the problem are not so much the shield tham the arms :
Most of them are made to hold a lasgun two-handed...
I know that we are a Power-armour only forum, but does any of you know if within 2 cadian troop box I will have enough "independent" arms to hold 3 swords & 3 shield?
