Calgar 2.0 Posted October 13, 2011 Share Posted October 13, 2011 Last time I had a topic on the Liber forums, I was a bit hot-headed, and didn't accept help or c&c for design. However, I feel I have grown since than (if you call playing with toy soldiers growing up ;)). So here is my new foray into the DIY aspect of the Space Marines. The Imperial Rangers are a non-codex chapter that is descended from either Raven Guard, or Dark Angels. They basically are based in 9 different fortresses in 9 different systems, and having little to no contact with the other fortresses. That's the bit I'm thinking of cutting in favor of other communicative (?) methods. They hold civilian life above their own, and will therefore go through hell and back to protect civilians, kinda similar to the Sallies on Armageddon. They prefer range combat, but will get into the melee if needed, such as the above situation. They have some units like the Mantis Warriors' Tranquility Snipers, that typically go through extra scout training to hone marksmanship. They are also adept in using grav-chutes in operation with small unit tactics. So that's what I have so far. It's not well written, probably due to the fact that I'm more used to making fluff for my guard force. C&C Welcome -Calgar Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/ Share on other sites More sharing options...
Brother Melice Posted October 13, 2011 Share Posted October 13, 2011 Bro, here are my thoughts o this. I dig the fundamental idea of split forces, so i'd expand on that. Valuing civilians is a nice touch on their character and warfare approach, so a definite yes there. My concerns is dual approach in warfare tactics, if they prefer long ranged warfare, run with it, if you build around that, it will add flavour, say minimum of two dev squads in armies, and restrict CC units. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2899028 Share on other sites More sharing options...
InquisitorHayn Posted October 13, 2011 Share Posted October 13, 2011 Welcome back to the Liber! Now as far as your concept I have two questions: 1)What do you want your central theme to be? The driving force of the Chapter? 2)Why grav-chutes when you have jump packs? That's like riding a moped when you have a Harley in the garage. Unless, of course, you're creating the first Chapter of environmentally conscious Space Marines. <_< Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2899152 Share on other sites More sharing options...
Calgar 2.0 Posted October 13, 2011 Author Share Posted October 13, 2011 Welcome back to the Liber! Now as far as your concept I have two questions: 1)What do you want your central theme to be? The driving force of the Chapter? 2)Why grav-chutes when you have jump packs? That's like riding a moped when you have a Harley in the garage. Unless, of course, you're creating the first Chapter of environmentally conscious Space Marines. :lol: Thanks for the warm welcome =][=hayn. Well, I'm basically running off of a concept I made with Deathwatch with my Marine taking Drop Operations as a combat specialty, probably not a good idea to base one chapter off of a single marine though, huh? The central theme I would like to have is a almost modern military feel, while still retaining their Imperial Space Marine identities, if that can be understood. Brother Melice, thanks for the feedback, I agree that putting some restrictions on CC units would be needed, but not enough so that there aren't any at all. The 2 devestator is an interesting idea, and one I will probably try to use. -Calgar 2.0 Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2899313 Share on other sites More sharing options...
Dosjetka Posted October 13, 2011 Share Posted October 13, 2011 The central theme I would like to have is a almost modern military feel, while still retaining their Imperial Space Marine identities, if that can be understood. Seems to be a common trend these days... :lol: Nice colour scheme, by the way ^_^ Ludovic Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2899317 Share on other sites More sharing options...
Calgar 2.0 Posted October 13, 2011 Author Share Posted October 13, 2011 The central theme I would like to have is a almost modern military feel, while still retaining their Imperial Space Marine identities, if that can be understood. Seems to be a common trend these days... :lol: Nice colour scheme, by the way ^_^ Ludovic Thank you. As to, it being a common trend, maybe, I just haven't seen it accomplished very well, unless it was something like Brother Melice's army. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2899322 Share on other sites More sharing options...
Brother Rathul Posted October 14, 2011 Share Posted October 14, 2011 I don't think Space Marines can use grav-chutes bud. Space Marines are heavy, shock infantry. The U.S. Army Rangers you base your chapter off of are light infantry designed to raid, recon, fire control, and seizing ground. Marines in the other hand are heavy, amphibious infantry. Hence the reason they are called Space Mairnes and not Space Rangers. But kudos to you sir, maybe make an airborne designed chapter instead. Kinda like the Hawk Lords. I had a DIY chapter kinda like your's called the Red Devils, you are free to look it up and use anything from it if you'd like. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2899736 Share on other sites More sharing options...
NightrawenII Posted October 14, 2011 Share Posted October 14, 2011 *walks in* The grav-chutes, or something similar, are used when dropping from StormRaven. The previous attempts of "Ranger" Chapter. Rangers lead the way..., Crazy thought but hear me out... The Shadow Of Terra, Raven Guard Succsors Nytrian Rangers, Aussie Space Marines Thought of the Day: Wise men learn from death of others. Cheers, NightrawenII. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2899862 Share on other sites More sharing options...
Marshal Rohr Posted October 14, 2011 Share Posted October 14, 2011 Graduate Imperial Ranger school in 60 days and get a second tomahawk! FREEEE! Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2900056 Share on other sites More sharing options...
Calgar 2.0 Posted October 15, 2011 Author Share Posted October 15, 2011 *walks in* The grav-chutes, or something similar, are used when dropping from StormRaven. The previous attempts of "Ranger" Chapter. Rangers lead the way..., Crazy thought but hear me out... The Shadow Of Terra, Raven Guard Succsors Nytrian Rangers, Aussie Space Marines Thought of the Day: Wise men learn from death of others. Cheers, NightrawenII. Thanks for the input on the grav-chutes, as that is what I would imagine it would be there for. As for those failed attempts,that is not what I want what so ever. I would like to have a chapter that is on the fringes of Imperial territory protecting the Imperium's citizens. I don't want marines to act as the modern day soldier. Some things could be used, such as squad structure, and a very sterilized rank structure, but no bush-wacking, or air assaults as we do with helicopters. As for the stormravens, that could be something that I could try if they add them in next edition, so thanks for that. Marshal2 Crusaders, was that supposed to be a constructive critique? Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2900541 Share on other sites More sharing options...
Hyaenidae Posted October 15, 2011 Share Posted October 15, 2011 Graduate Imperial Ranger school in 60 days and get a second tomahawk! FREEEE! You'll kick tigers with your Ranger legs!! :P This is what Marshall2Crusaders is talking about (Make sure the kids are outta the room for this one...) There is some slight support for Air Assaults from Thunderhawks, such a thing was done in the second Soul Drinker book. Really, take it or leave it, just wanted to let you know there's precedent for it. As for the idea, it's pretty decent, although it's hard to say more than what has already been said, with the concept still in it's infancy. Start hammering out some more ideas, and we'll continue helping where we can. If anything, I'd suggest studying up on Merrill's Marauders, the 1st Special Service Force (also known as the Devil's Brigade), the US Army Ranger regiments (specfically the 75th Ranger Regiment) and staring long and hard at the Ranger Creed. Hopefully, this all helps. Best of luck, bro. All The Way! Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2900569 Share on other sites More sharing options...
Calgar 2.0 Posted October 15, 2011 Author Share Posted October 15, 2011 Graduate Imperial Ranger school in 60 days and get a second tomahawk! FREEEE! You'll kick tigers with your Ranger legs!! :cuss This is what Marshall2Crusaders is talking about (Make sure the kids are outta the room for this one...) There is some slight support for Air Assaults from Thunderhawks, such a thing was done in the second Soul Drinker book. Really, take it or leave it, just wanted to let you know there's precedent for it. As for the idea, it's pretty decent, although it's hard to say more than what has already been said, with the concept still in it's infancy. Start hammering out some more ideas, and we'll continue helping where we can. If anything, I'd suggest studying up on Merrill's Marauders, the 1st Special Service Force (also known as the Devil's Brigade), the US Army Ranger regiments (specfically the 75th Ranger Regiment) and staring long and hard at the Ranger Creed. Hopefully, this all helps. Best of luck, bro. All The Way! Lol, that video was good for my 17 year-old mind. :D Thanks for the advice on the air assault acpect, however, as was stated I don't want to have "teh uber-cool ranger marines". Those might work for my scouts though. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2901017 Share on other sites More sharing options...
Sigismund Himself Posted October 16, 2011 Share Posted October 16, 2011 The central theme I would like to have is a almost modern military feel, while still retaining their Imperial Space Marine identities, if that can be understood. What exactly do you mean by 'modern military feel'? :) Space Marines are kind Modern Military dialled up to 11 on the amp. They live and breath war, they have war for breakfast and all the other cliches you can think of. Were you thinking of a less superstitious chapter? I'm just not quite sure what exact aspect of it you were going for. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2901062 Share on other sites More sharing options...
Calgar 2.0 Posted October 16, 2011 Author Share Posted October 16, 2011 The central theme I would like to have is a almost modern military feel, while still retaining their Imperial Space Marine identities, if that can be understood. What exactly do you mean by 'modern military feel'? :) Space Marines are kind Modern Military dialled up to 11 on the amp. They live and breath war, they have war for breakfast and all the other cliches you can think of. Were you thinking of a less superstitious chapter? I'm just not quite sure what exact aspect of it you were going for. That's it. A less religious chapter, although they do have a couple Chappies, that just fight to protect. That's it. Some more fluff will be posted tomorrow. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2901067 Share on other sites More sharing options...
Brother Rathul Posted October 17, 2011 Share Posted October 17, 2011 Graduate Imperial Ranger school in 60 days and get a second tomahawk! FREEEE! YOU'L FIGHT TIGERS YOU WILL FIGHT THEM UNDER WATER!!! hahaha I believe they use jump packs to jump out of storm ravens, not grav chutes. Power armor would be too heavy to use grav-chutes. Perhaps an Airborne feel for your chapter instead? Brother Rathul Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2901549 Share on other sites More sharing options...
Calgar 2.0 Posted October 17, 2011 Author Share Posted October 17, 2011 Graduate Imperial Ranger school in 60 days and get a second tomahawk! FREEEE! YOU'L FIGHT TIGERS YOU WILL FIGHT THEM UNDER WATER!!! hahaha I believe they use jump packs to jump out of storm ravens, not grav chutes. Power armor would be too heavy to use grav-chutes. Perhaps an Airborne feel for your chapter instead? Brother Rathul As I had said, Astartes-class grav-chutes are options for wargear in Deathwatch. However, an Airborne is something I am trying to get. Okay, the little bit of fluff thatI have comeup with: -9 Fortresses in 9 different systems: - Fortress Ultima in Angelis System ++Fighting off xenos invaders++ - Fortress Enigma in Dunwich System - Fortress Voena in System Gamma-c11 Okay, thats 3 of the 9 fortresses across the Emperor's Segmentae(?). Commander of Fortress Enigma (aka my future army's captain) is Captain Edson. He survived a nuclear holocaust brought about by rival nation-states (kind of like the Gaunt's Ghost book Straight Silver). He was found by the Imperial Ranger fighting to protect his settlement alongside 5 other men, from a company's worth of chaos cultists, using ambushes, and specially place booby traps. He was inducted after a small force of Imperial Rangers came to investigate elevated radiation levels, and went into the scout section alloted at Enigma. He showed tremendous skill as a sniper and, when he became a space marine proper, was assigned as a Tactical squad sniper. He was issued a Stalker-pattern bolter, and is credited with hundreds of kills in one campaign alone. ++More to follow++ -Calgar 2.0 Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2901579 Share on other sites More sharing options...
Retributis Posted October 18, 2011 Share Posted October 18, 2011 Remember that marines take pre-pubescent children as recruits, so 6 12 year olds holding off a company of chaos cultists in a straight fight might seem a bit "RAWR AWESOME". Why not take some more inspiration from G's Gs and have them running a rag-tag scratch company of children after their parents have been killed by the cultists. Sneaking around battles between the remaining PDF forces and picking their ambushes as and when they can to survive. That sort of scenario would set a precedent for his tactical and command skills before recruitment, his hardiness as a survivor and as a fighter, it would serve to further enshrine why he especially holds civilian lives so dearly and is a bit less rambo last stand conjuring than a straight up battle. Just a thought :) Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2902827 Share on other sites More sharing options...
Calgar 2.0 Posted October 18, 2011 Author Share Posted October 18, 2011 Remember that marines take pre-pubescent children as recruits, so 6 12 year olds holding off a company of chaos cultists in a straight fight might seem a bit "RAWR AWESOME". Why not take some more inspiration from G's Gs and have them running a rag-tag scratch company of children after their parents have been killed by the cultists. Sneaking around battles between the remaining PDF forces and picking their ambushes as and when they can to survive. That sort of scenario would set a precedent for his tactical and command skills before recruitment, his hardiness as a survivor and as a fighter, it would serve to further enshrine why he especially holds civilian lives so dearly and is a bit less rambo last stand conjuring than a straight up battle. Just a thought ;) Ah, good point. I was thinking he would be 15-17, but you are right. Thanks for the c&c. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2903089 Share on other sites More sharing options...
NightrawenII Posted October 20, 2011 Share Posted October 20, 2011 -9 Fortresses in 9 different systems: - Fortress Ultima in Angelis System ++Fighting off xenos invaders++ - Fortress Enigma in Dunwich System - Fortress Voena in System Gamma-c11 Okay, thats 3 of the 9 fortresses across the Emperor's Segmentae(?). -Calgar 2.0 I was wondering about this for some time, but since I can't find any explanation, I'm going to ask: WHY? Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2904634 Share on other sites More sharing options...
Marshal Rohr Posted October 20, 2011 Share Posted October 20, 2011 Break up the dispersion and training to be more the the Reg. 3 fortresses on 3 Planets: Each with a Combat Team/Strike Force/Whatever made of 3 Companies. 1 Recruitment World: Garrisoned by the HQ and 10th Co etc. The parralels are there. Just drop the Ranger from the name. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2904822 Share on other sites More sharing options...
Leonaides Posted October 20, 2011 Share Posted October 20, 2011 Biggest problem with that is thats 3 places that might be holding geneseed/relics, but none of them are secure when any of your marines are on missions... Or do your marines only venture out 1 company at a time from each base (assuming 1 garrisoning, 1 recovering from losses/re-equiping and 1 on patrol). Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2904973 Share on other sites More sharing options...
bilbo7788 Posted October 20, 2011 Share Posted October 20, 2011 Easier would be 9 forteresses on 9 planets in the same system. The 9 planets (and associated company) could be competing to create the best forces in the service of the Emperor... Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2905002 Share on other sites More sharing options...
Marshal Rohr Posted October 20, 2011 Share Posted October 20, 2011 Relics would likely be with the 10th co since classes would always be cycling through. Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2905003 Share on other sites More sharing options...
Leonaides Posted October 20, 2011 Share Posted October 20, 2011 So the 3rd co wouldnt keep their own relics? Their own company banners? Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2905118 Share on other sites More sharing options...
Calgar 2.0 Posted October 20, 2011 Author Share Posted October 20, 2011 Break up the dispersion and training to be more the the Reg. 3 fortresses on 3 Planets: Each with a Combat Team/Strike Force/Whatever made of 3 Companies. 1 Recruitment World: Garrisoned by the HQ and 10th Co etc. The parralels are there. Just drop the Ranger from the name. Wow. This thread exploded with activity today. Thank you for that Marshal2 Crusaders, that actually sounds like a better idea in the long run for the fortresses. However, I like the name, because it's not omething you see often for the SM. So the 3 fortresses will be those already listed, because I like the names best *cringes*. The companies will keep teir banners, which will be like the banner used in Collected Visions, that is reminescent of American Civil War era banners. As Leonaides sugested the deployment will be in that kind of schedule. Each company would keep their own relics, as well, because military units don'tusually like having stuff of special importance taken from them. -9 Fortresses in 9 different systems: - Fortress Ultima in Angelis System ++Fighting off xenos invaders++ - Fortress Enigma in Dunwich System - Fortress Voena in System Gamma-c11 Okay, thats 3 of the 9 fortresses across the Emperor's Segmentae(?). -Calgar 2.0 I was wondering about this for some time, but since I can't find any explanation, I'm going to ask: WHY? Wouldn't it make more sense to be able to have more area's covered in the unforgiveing galaxy? Link to comment https://bolterandchainsword.com/topic/240202-imperial-rangers/#findComment-2905231 Share on other sites More sharing options...
