Spare Sprue.
Zincite
I've just received a load of spare sprues off eBay. From what was left on them, I believe the guy had assembled his army and just left anything he didn't want on the sprues, which is what I got. Having now clipped out all my parts (My Hive Tyrant is very happy with his new arms), I've got a lot of spare sprues to hand.
It seems a waste to just throw them out, anyone have any ideas on what to go with them? Only thing serchy has found is this
I was thinking of sharpening them into 'spikes' and planting them in polystyrene, painting and using as scenery, but I'm looking for any ideas. ;)
https://bolterandchainsword.com/topic/240333-spare-sprue/
I've used sprue for various things including the base of bionic limbs, fences, guard rails, frame work for buildings or other items made from card/foamcore, rubble for ruins & bases, extra armor on tanks (which, when painted like concrete looks awesome), iron maidens.
I just use my imagination when I need to build something & usually can find some way to make it happen w/ the sprue as a start.
https://bolterandchainsword.com/topic/240333-spare-sprue/#findComment-2901481
I've used it for supporting razor-wire fences (with the use of cardboard and a bit of GF9 razor wire (I think)).
I sharpened a bit and used it on a Carnifex base and it looks like either a stone spike or a broken steel beam sticking out of the sand.
I could imagine using it as framing for buildings, rubble (seen this, if you chop it up randomly into medium and short pieces, pile it together, and pour a bit of glue over it and maybe some sand or flock, it looks really nice).
You can also make pretty convincing tank traps with it.
I will need to try that extra plating idea though!
https://bolterandchainsword.com/topic/240333-spare-sprue/#findComment-2901501
  • 3 weeks later...
Ah, fences indeed. Take two 3 or 4 inch pieces of spare sprue that have been trimmed straight, and where the widest flat portion is glue them together with chain mesh inbetween. It gives the fence posts more heft than your standard chain link fences, and the blocky posts fit more in line with Imperial architecture. Hand twisted barbed wire coiled in loops on top make a nice addition (22 gauge galvanized steel wire?)
Filling the gap between the two sprue posts can be done with a touch of green stuff, or with any kind of epoxy. Or you could file a sliver away from the portion where the mesh will insert. Mount the posts on a row of plaster blocks (I like the Hirst arts molds for this) and you have a stable fence that won't tip over with a stiff breeze of body odor.
https://bolterandchainsword.com/topic/240333-spare-sprue/#findComment-2916508
If you can find an old crank meat grinder, (Check at some second hand stores - they are almost indestructible so they are easy to find) and have a very secure place you can clamp it, you can use it to 'grind' those sprews down rubble very quickly. It even mangles and chews up the sprew to make it look very convincing.
The key is to have a very secure place to clamp the grinder. It takes a lot of torque to force plastic through even a coarse meat grinding plate.
https://bolterandchainsword.com/topic/240333-spare-sprue/#findComment-2917114
I ran my first batch through one of these last night. Several frames of AoBR sprue from the Terminators. It was a workout. One thing you do NOT want to do is put long lengths of sprue in the hopper. I started with some 4" long sections, and they just jammed up in the feed screw. I had to cut them down to about 1-2" long to make sure they made it to the grinder head. Once they made it through, it produced some really neat pieces. Most about the size of a Marine head. Great for scattering on terrain pieces, not so wonderful for use on model bases. It's just too torn up to look like rocks.
https://bolterandchainsword.com/topic/240333-spare-sprue/#findComment-2918532
Well said. Good information. I'm avoiding doing anything on a table until my army is where I want it. Last thing I need is more distractions. So, I haven't really done this in mass, just some tests.
I do want to do a City Fight theme for my first table, and saw this idea years ago. It appeared to produce the best 'building rubble', and without endless snipping, just brute force.
https://bolterandchainsword.com/topic/240333-spare-sprue/#findComment-2918611
it was a long time ago but i remember a thread in the work in progress section ware a guy was building a dreadnought using only sprew peaces for the bulk of it
I do believe I am the slack owner of the thread you are referring to. :) Link to the dreadnought thread is in my sig. Am hoping to return to it after a sort out a few other issues. :D
https://bolterandchainsword.com/topic/240333-spare-sprue/#findComment-2919908
