SW Contemptor...
LPetersson
anybody seen or read the entry of the SW Contemptor?
heres what i gleemed (dont know why i put it in spoiler tags, just in case somebody has the apoc book on order and wants to wait to read it themselves.
Basically the SW entry makes it clear Fluff wise why Bjorn is not in a contemplator.
Basically those inturned in contemplators were prone to bloodlust and excessive overkilling. The wolf priests were hesitant to put great warriors in them, Hence Bjorn is in the more easily maintained and safer version.
Its said about comtemplators that the SW look at them with an equal mix of awe and supicion. (not in the supersiosios way but more in the way that they are unstable/ like they would at a SW who is showing signs of being wolf bitten)
Also they get sagas that give them things like +armour pen roles
and armoury stuff like wolf tooth necklaces and talismans.
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2902407
Is the wolf contemptor elite or heavy support? My elite slots are always full... :)
I guess the Contemptor is for those Apoc games anyway, so the actual slot doesn't matter...
I'll very much buy one for my army as soon as I can decide what armament to order it with. And that means I need to see the rules first. Unless you guys already have good suggestions for the arms, which ones to buy?
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2902654
Thanks Beef, that's good to know. I'm waiting for my local GW to get the new IA book.
What you say matches what I'm hoping to do quite well as I want to make mine a close combat beast with a CML on top. although I disagree on one thing, there is no such thing as overkill :)
Beef, have those rules been released yet? I thought they were in the next FW IA book that's got Bran and whatnot. Or is this in the new Apoc book I've yet to pick up?
I believe, and I could be wrong, that they are in the new Imperial Armour Apocalypse 2nd edition book (http://goo.gl/xQC2L) as opposed to the coming book with SW and DE.
I am under the impression the Contemptor is an elite choice and it is valid for normal games of 40k, not just Apoc.
You can see the experimental rules here http://goo.gl/E95d9 although they might be different in the IA book.
To my mind, you need to decide whether yours should be long range, mid range or close up delivered by Lucius Pattern Drop Pod ;-)
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2902667
Yeah...that's something I noted on another thread. While it presently isn't explicitly stated (and therefore RAW, isn't legal), FW has apparently suggested to another B&Cer that the Lucius Pattern pod will support Contemptor pattern Dreadnoughts. Eventually. When they get round to fixing that via errata or new publication.
At present, they're hoofing it with Bjorn.
As for load-out...magnetize the hell outta the guy and get the shedload, is my advice.
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2902692
What you say matches what I'm hoping to do quite well as I want to make mine a close combat beast with a CML on top. although I disagree on one thing, there is no such thing as overkill ;)
Thats true
Nope
COrrect
Is the wolf contemptor elite or heavy support? My elite slots are always full... ;)
Go with what looks good, forget the rules
Correct, although the SW version and the BA version have their own snazzy special rules
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2902780
Is the overkilling penchant due to the nature of the machine spirit within the Contemptor or has it not been fully explained yet?
I ask because I've read that some machine spirits like the ones in titans are violent and actively attempt to subsume the personality of the pilot.
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2903023
Ooooh Bjorn in apod... dang you FW now I have to spend even more $!
No you dont, just use a normal drop pod and state its a Lucious. However i am not sure Bjorn can still use it. The difference between the lucious and normal drop pods for dreads is that dreds can assualt straight out of a Lucious. This is shown in the points difference between the drop pods. The luciosu is 65 pts if i remember correctly. If Bjorn does not have a tarnsport option than surely he cant take this unless GW FAQ this. Right?
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2904064
suprisingly its only the SW ones that suffer the extra violent urges, hence they are not trusted by their own warriors. Its just the Fluff explanation by GW to explain why somebody as beloved of the chapter as Bjorn is not in an older dred like the contemptor. Yet suprisingly on the chaos entry it says they do not suffer the madness common to the newer marks of dred armour we usually see.
So the Chaos Contemptors are very much in control of their sences unlike their newer counterparts and many chaor lords keep a few empty one for themselves.
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2904068
I can't wait untill the GW stores get the apoc second edition book in so I can swing in and grab it.
I'm really looking forward to running a contemptor as I love dreads of all types and it sounds like exactly what I've been looking for. A dread to run in and punch things in the face!
https://bolterandchainsword.com/topic/240453-sw-contemptor/#findComment-2905278
