Iron Fillings
Not only would it not be of questionable magnetic strength, but the attachment point would be unfocused. There'd be nothing to prevent the arm from slipping down to the Marine's bellybutton or his hip, since the entire torso area would be filled with magnetic material.
Arm magnetization is typically done with magnets in the shoulder joint of the torso, and additional magnets in the shoulder joint of the arm. Anything less is unreliable.
https://bolterandchainsword.com/topic/240484-iron-fillings/#findComment-2902856
Iron fillings won't be able to maintain the kind of attraction you're looking for. The "sciencey" answer would be that the magnetic attraction between a magnet and a chunk of metel depends on the magnetic field inducing an electric current in the bulk material which creates a reciporocal magnetic field in the opposite direction. But the short answer is no it won't hold.
https://bolterandchainsword.com/topic/240484-iron-fillings/#findComment-2903031
I use 3mm rare earth magnets. One in the shoulder, one in the arm. It fits well but it is a bit tricky to get it 100% right for weapons which are held in both hands :D But it's not too hard either.
Just make sure that you do not mess up your magnet orientation! There is nothing more annoying than having marines which cannot take all equipment I have because the magnets are not correct ;)
https://bolterandchainsword.com/topic/240484-iron-fillings/#findComment-2903539
