Did the Alpha Legion have Librarians?
That's basically the question. I'm working on a small true scale PH Alpha Legion force counts as some Terminatorwing, and I like the idea of including a librarian (behaving very sneakyly of course) of some sort.
So my question would be; Does anybody know/ Is there a reason why Alpha Legionnaires should not have had libbys before the Council of Nikea or after they turned "traitor"?
Agreed. It's obvious that A&O were comfortable with using psykers, so it's not far fetched to assume they did indeed use librarians before Nikea and started using psychic agents once marine psykers was out as an option.
Altough as Nikea only forbid psykers from using psychics, not removed their powers, it's a bit odd A&O didn't just decide to continue using librarians under the table. Well, maybe they just decided that to seemingly comply and then use hired hands is more sneaky.
Not only that, but when an AL Librarian says, "I am Alpharius" you are compelled to believe him. :P
That being said, I intend to use the GK codex to represent my AL. I got the idea from Migsula and think that codex gives you a very interesting way to build an army, especially with operatives.
Could the Alpha Legion have had transfers to thier legion? Such as a Thousand Sons Librarian or a Word Bearers Chaplain?
Not sure that they would have accepted them into thier secrecy, but makes for an interesting modeling option in my opinion.
The thing about the Alpha Legion is..
You don't know.
I mean, let's just take Legion as full canon, face value; no tricks or deception or whatever, for the sake of this argument.
The Alpha Legion is shown as being almost entirely uniform in appearance. Alpharius (presumably the real one) has a slightly more ornate suit of armour in the closet for the big get together they have with the Imperial Army commander guy, but otherwise wears armour that looks like the average line trooper. He makes it a point of trying to look like everyone else so that he can move about as unseen as possible.
Omegon is mostly the same, except for his stealth armour, which has portions blackened out, and some kind of radar deflecting ability so he can take a stroll through a sensor field.
Omegon and Alpharius are a few inches taller than the legion average so they have a couple of the taller marines hang around them so they can switch places easily.
I imagine that any librarians, such as they are, would do much the same. Likely they'd be as similar to the rest as possible, but have their librarian tricks on standby too. They'd be an ace in the hole, yes, but likely they'd resort to that only if needed.
Thanks for all the answers guys, did help a lot ;)
I'm now in the building-stage of the army and right there I have run into another issue. I will run my 27 Alpha Legionnaires (cause that's all you get for 1850 points^^) as Grey Knights, and all the weapon options work just fine (falxes as Halberds, one-handed Bolters as Stormbolters, Powerfists/Chainfists as Demonhammers etc...) but the warding staves just won't fit.
So my next decision would be:
Leave Warding Staves out (for fluff purposes) or keep them (for cool in-game moments). If I decide on keeping them, do any of you guys know a good way of making counts-as weapons that would double for Warding staves easily?
Any feedback is appreciated, I think I'll even get some pics up as soon as possible :huh:
I think that Alphas as Grey Knights is a bad idea, bro. Your justifications are flimsy -- one handing a bolter doesn't make it an Assault weapon -- and even if the Alphas did have Librarians, I very much doubt they had one in every single squad.
That's not the point actually, GK are the best way to create an army with the lowest model count ever, and that's what I want, really.
And in addition, I admittedly only tried the demo of Space Marine, but if a Bolter in conjunction with a nice blade isn't a badass assault weapon, then I don't know what weapon would be...
@CE: Unless you really feel like you need a warding stave, I'd leave it out, mostly because it does exactly what the AL don't want to do, which is "stand out".
If you want the effect, then possibly add a second sword, either wielded or in it's scabbard to represent some super awesome parrying skills.
I'm really looking forward to your work.
Cheers,
