red_starrise Posted October 28, 2011 Share Posted October 28, 2011 Ok, I'm doing Iron Warriors but I've run into a bit of a brick wall here & was hoping for suggestions from other Iron Warrior players as well as Silver Skulls etc. My question is: How do you paint tracks & battle damage to make them stand out from a primary color of boltgun metal highlighted w/ mithril silver? Link to comment https://bolterandchainsword.com/topic/241068-detailing-steel-colored-tanks/ Share on other sites More sharing options...
Hyaenidae Posted October 28, 2011 Share Posted October 28, 2011 Check out Nurgling6688's Astral Claws thread (Link Here!), very nice chipped and damaged steel armour. Hope this helps! :) Link to comment https://bolterandchainsword.com/topic/241068-detailing-steel-colored-tanks/#findComment-2911353 Share on other sites More sharing options...
red_starrise Posted October 28, 2011 Author Share Posted October 28, 2011 Check out Nurgling6688's Astral Claws thread (Link Here!), very nice chipped and damaged steel armour. Hope this helps! :) Thanks, that is a help. Any ideas on doing tracks on tanks so they don't just blend? On some of my tanks they go all the way round like IG tanks so they're very prominent. Link to comment https://bolterandchainsword.com/topic/241068-detailing-steel-colored-tanks/#findComment-2911370 Share on other sites More sharing options...
Lorenzen Posted October 28, 2011 Share Posted October 28, 2011 PJ1933 has an excellent recipe for tanks.. so much so that i stole it. Tracks are painted dark flesh and then heavy washed with badab black but it depends how old you want them to look you could use a dark grey instead of dark flesh for a fresher look. Then after pigments are added I try to pick out the tread pattern with a light drybrush of gunmetal a graphite pencil can work for this too. http://www.bolterandchainsword.com/index.p...240507&st=0 Link to comment https://bolterandchainsword.com/topic/241068-detailing-steel-colored-tanks/#findComment-2911378 Share on other sites More sharing options...
