Need tips on how to make thunderhammer for thunderwerewolf
Token
I asked over at the wip forum, but dont think i got any answers on ideas of how to make a thunderhammer and storm shields for my thunderwerewolves (counts as thunderwolf cavlary).
Opinions on base size are wellcome too. Should they be mounted on big bases, as Canis is, or the medium "termie" base?
Edit: forgot the link... http://www.bolterandchainsword.com/index.p...howtopic=240932
PA SS and TH's can be found in the standard SW grey hunter/bloodclaw box. other PA SS and TH's can also be found in one of those BA boxes as can they be found in the grey knight box i believe.
the other option is to use TH's and SS found in various terminator boxes
sorry! mind was foggy from goping out so i only read half the topic title! the ork nobs have some weapons that are quite big. i'm sure you can fit one of those on 'em. forgeworld also sells these huge black templar stormshields that you might be able to use
Wow, those shields were big, could work. Not sure i like the black templar markings though, could they be carved away and replaced with a wolf skull or something instead perhaps?
None of the ork weapons are hammers, right? Perhaps the handles could be usefull. What could be used as a hammer head(is that the right word?)?
Tips and opinions are welcome.
Thanks for the tips. Not sure i like metall parts, but might work. Is there some bitz site that sells warjack parts?
Skoll, the poem/text in your sig, where is that from?
I made it up when i was bored one night.
Privateer press sells all their bitz individually
http://store.privateerpress.com/parts.aspx
  • 3 months later...
been doing some more work on my thunderwerewolves. Perhaps getting better.
The left shouderpad got big, but the right one got really big, will perhaps cut some off and change it that way.
Edit: Learned that plastic can melt if to close to a lightbulb turned on. Also that greystuff can become brown.
http://i1179.photobucket.com/albums/x389/Torkor/Thunderwerewolf12.jpg
http://i1179.photobucket.com/albums/x389/Torkor/Thunderwerewolf13.jpg
http://i1179.photobucket.com/albums/x389/Torkor/Thunderwerewolf14.jpg
Not sure of the scale that you are working with... but would the shields in the fantasy chaos knights work? There are other bits on those sprues that could be used with some work for the rest of your troops if you need them. Might be a bit on the small side though. Just a thought. Might actually line up decently, but then again I am not sure how big they are since I haven't seen them in person.
Crazywolf
