Joe Mama Posted November 3, 2011 Share Posted November 3, 2011 You put enough of those little guys together and they can shoot out a high strength armor ignoring blast. Four guys gets you Strength 6 AP 3. Six guys gets you strength 8 AP 1. 36 inch Large Blast! And they are only 10 points each. But, they are only LD 8 and BS 3. Their power may not go off, or miss. If perials happen they all die. Still, they are cheap enough to take 2-3 squads mounted in Rhinos./ Anyone use these henchmen how did they turn out? Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/ Share on other sites More sharing options...
Jacinda Posted November 3, 2011 Share Posted November 3, 2011 WT...? Oh, 36" range, large blast. That makes more sense than what I first though. ;) Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915728 Share on other sites More sharing options...
Joe Mama Posted November 3, 2011 Author Share Posted November 3, 2011 ;) I typed quickly. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915735 Share on other sites More sharing options...
Something Wycked Posted November 3, 2011 Share Posted November 3, 2011 Well, consider that the average roll on 2d6 is 7, and you'll see that whether or not they get their ability off every turn is very much in doubt- without taking into account any psychic defenses the opponent may have. So, while inexpensive, they aren't stable enough for me to include them in my lists. Control, control, you must learn control! Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915737 Share on other sites More sharing options...
Chengar Qordath Posted November 3, 2011 Share Posted November 3, 2011 On the other hand, being Assault 36" means they can out-range most psychic defenses, and one solid hit will more than earn back their points. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915791 Share on other sites More sharing options...
Something Wycked Posted November 3, 2011 Share Posted November 3, 2011 ...they can out-range most psychic defenses... For at least a couple turns, until the psychic defense moves into range. And then you have to hope that your Leadership rolls on those first couple turns succeed since you are more likely than not going to fail to get the power off once the psychic defense comes into play for various reasons. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915794 Share on other sites More sharing options...
Joe Mama Posted November 3, 2011 Author Share Posted November 3, 2011 Rolling an 8 or less happens 70%-ish of the time, so they aren't that horrible. Because they are so cheap you can have two squads of them to increase the odss,or add them to two already shooting squads. 6 psykers is S8 AP1, 2 groups of 6 is only 120 points. For the potential of 1 or more S8 AP1 large blasts hitting a bit above 60% of the tmie (this is what some math geeks figured out on a blog), that isn't that unreliable. I am just starting my henchmen / grey knights hybrid list, so maybe I am totally wrong, but it seems like they can make their opoints back. On the other hand, being Assault 36" means they can out-range most psychic defenses, and one solid hit will more than earn back their points. :) you posted while I was typing. That is a good point! Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915792 Share on other sites More sharing options...
number6 Posted November 3, 2011 Share Posted November 3, 2011 I am definitely not a fan because of LD 8. They aren't truly cheap as chips, you know. They take up a precious Elites slot, if nothing else. And that LD 8 isn't just a hindrance for passing psyker tests. These guys die like flies, and since you will not want them anywhere near the center of the table, making them run off the table is trivially easy. Bleh. :) Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915799 Share on other sites More sharing options...
Joe Mama Posted November 3, 2011 Author Share Posted November 3, 2011 I would use them with Corteaz, so they'd be troops. And i'd put them inside a vehicle. Otherwise they are too easy to kill like you said. by the way, does Coteaz's I'll be Back ability work with psychic shooting attacks? Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915802 Share on other sites More sharing options...
Something Wycked Posted November 3, 2011 Share Posted November 3, 2011 And that LD 8 isn't just a hindrance for passing psyker tests. These guys die like flies, and since you will not want them anywhere near the center of the table, making them run off the table is trivially easy. Though, to be fair, giving them a vehicle to hide in can mostly fix that, especially if its a GK Rhino that's effectively immune to shaken/stunned. To throw numbers at the psychic defense: Alone, they will pass their test 72.22% of the time. In the face of a Space Wolf Rune Priest, their power will go off 36.11% of the time (Njal: 24.07%). In the face of Nids or Eldar and having to use 3d6, 25.92% chance to cast successfully. In the face of a SM Hood, 20.22% to succeed. And lets not get into casting against Grey Knights with Aegis/Reinforced Aegis :) Edit: Actually, here's a complete list from WarHamSandwich: http://warhamsandwich.files.wordpress.com/2011/10/screen-shot-2011-10-05-at-17-22-57.png Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915812 Share on other sites More sharing options...
thade Posted November 3, 2011 Share Posted November 3, 2011 If I had the models, I'd take a few now and a gain, for the lolz. Probably be fun to convert up. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915816 Share on other sites More sharing options...
staxer Posted November 3, 2011 Share Posted November 3, 2011 Some Eldar and Tyranid armies will make you roll 3d6 so with a low leadership it is not worthtaking them against a perils of the warp rolls Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915824 Share on other sites More sharing options...
*Furyou Miko Posted November 3, 2011 Share Posted November 3, 2011 I am definitely not a fan because of LD 8. They aren't truly cheap as chips, you know. They take up a precious Elites slot, if nothing else. And that LD 8 isn't just a hindrance for passing psyker tests. These guys die like flies, and since you will not want them anywhere near the center of the table, making them run off the table is trivially easy. Bleh. ;) Actually, they take an HQ slot, and with them you get a nicely equipped Inquisitor, as well as (potentially) a Chimera. Never underestimate the power of an Armour 12 transport that can carry twelve power armoured (or six terminator armoured!) models, five of whom can fire out of it. Oh, and the Multi-laser can instant death Eldar, Guard or Sororitas characters. >> Now I want to play a GK army just to put a unit of Paladins with two Psycannons led by a Grandmaster with a Psycannon in a Chimera. Because NO-ONE will expect a piddly little Chimera of carrying that kind of hitting power. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915830 Share on other sites More sharing options...
Something Wycked Posted November 3, 2011 Share Posted November 3, 2011 >> Now I want to play a GK army just to put a unit of Paladins with two Psycannons led by a Grandmaster with a Psycannon in a Chimera. Because NO-ONE will expect a piddly little Chimera of carrying that kind of hitting power. Could also put a OM =][= with Psycannon in there with 5 Purgations with 4 Psycannons and have all 5 fire out the top ;) Or, to bring this more on topic, attach that OM =][= to the squad of Psykers and they can both fire out the top ;) Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915837 Share on other sites More sharing options...
thade Posted November 3, 2011 Share Posted November 3, 2011 I mean, don't hold me in too low esteem when I admit that I don't think much of six paladins in a Chimera; chimeras are basically Rhinos. It's 1-2 turns of mobility that they can't assault out of. Mixed feelings there. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915853 Share on other sites More sharing options...
Abaddonshand Posted November 3, 2011 Share Posted November 3, 2011 I use them with my Ordo xenos inquisitor in a 1500pt list, and they are good fun. Besides, if they all suffer perils and die it's funny as hell, and it's no skin off the inquisitor's nose if the witches on his side happen to die trying to kill the witches on the other side (although I should mention my character is a hypocrit, as he's a psyker. On that note he also consorts with xenos, having 3 kroot mercenaries in his retinue, counts as DCA). Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915909 Share on other sites More sharing options...
thade Posted November 3, 2011 Share Posted November 3, 2011 ...ridiculously awesome right here... Awesome. Seriously awesome. :( Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2915915 Share on other sites More sharing options...
Chengar Qordath Posted November 3, 2011 Share Posted November 3, 2011 ...they can out-range most psychic defenses... For at least a couple turns, until the psychic defense moves into range. And then you have to hope that your Leadership rolls on those first couple turns succeed since you are more likely than not going to fail to get the power off once the psychic defense comes into play for various reasons. One of the advantages of being Assault 36" is the ability to move away from any advancing psychic defenses and keep shooting. Plus for any GK army your opponent's psychic defenses are a priority target anyway. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2916080 Share on other sites More sharing options...
Emperorwaffle Posted November 4, 2011 Share Posted November 4, 2011 I have found them to be quite useful. I run them with an inquisitor with psyocculum with great results. Their low leadership and splat factor are discouraging, but they also throw out a large blast at 36" as assault. That keeps them out of hood range and void. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2916162 Share on other sites More sharing options...
Brother Valerius Posted November 4, 2011 Share Posted November 4, 2011 I am definitely not a fan because of LD 8. They aren't truly cheap as chips, you know. They take up a precious Elites slot, if nothing else. And that LD 8 isn't just a hindrance for passing psyker tests. These guys die like flies, and since you will not want them anywhere near the center of the table, making them run off the table is trivially easy. Bleh. :( Non-Coteaz henchmen don't take up slots. :rolleyes: Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2916176 Share on other sites More sharing options...
BLACK BLŒ FLY Posted November 4, 2011 Share Posted November 4, 2011 I think they could be a great choice for a Coteaz henchmen list. One unit with enough psykers to reach AP1 could work well I think. G :rolleyes: Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2916178 Share on other sites More sharing options...
Chengar Qordath Posted November 4, 2011 Share Posted November 4, 2011 I have found them to be quite useful. I run them with an inquisitor with psyocculum with great results. Their low leadership and splat factor are discouraging, but they also throw out a large blast at 36" as assault. That keeps them out of hood range and void. Hadn't thought of it before, but a Psyocculum would make Psykers pretty murderous against any enemy unit containing a psyker. As long as you can manifest the power, it's an auto-hit (even at max scatter, you'd only move 2" with a 5" blast template). Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2916209 Share on other sites More sharing options...
Something Wycked Posted November 4, 2011 Share Posted November 4, 2011 One of the advantages of being Assault 36" is the ability to move away from any advancing psychic defenses and keep shooting. Plus for any GK army your opponent's psychic defenses are a priority target anyway. The assumption here is that a 6" move of the vehicle is enough to keep them out of range of things that might be closing at a rate of 12" or more ;) Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2916526 Share on other sites More sharing options...
Chengar Qordath Posted November 4, 2011 Share Posted November 4, 2011 One of the advantages of being Assault 36" is the ability to move away from any advancing psychic defenses and keep shooting. Plus for any GK army your opponent's psychic defenses are a priority target anyway. The assumption here is that a 6" move of the vehicle is enough to keep them out of range of things that might be closing at a rate of 12" or more ;) You missed (or deliberately ignored) the second part of that post. Yes, if an opponent has a fast-moving Librarian who is completely focused on getting into hood range of that one squad and nothing else, he'll eventually pull it off. Mobility buys time though, and every turn your Psykers can still shoot is another turn where they can drop a Strength 8 AP 1 pieplate on that Librarian's (or whatever else's) head. Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2916677 Share on other sites More sharing options...
Something Wycked Posted November 4, 2011 Share Posted November 4, 2011 Yep, deliberately ignored, but since you want one, here's your response: there's a huge chasm between "priority target" and "definitely killed before he's in range." ;) Link to comment https://bolterandchainsword.com/topic/241396-henchmen-psykers/#findComment-2916711 Share on other sites More sharing options...
