The Army Painter Products
crocker
Hey Brothers!
TheArmyPainter.com is a website offering some wargaming products for painting and showing you how to "dip" your mini's into different tones for shading and just wants to get a veiw on buying these products and if anyone has had any experience with them?
Cheers,
Chris
https://bolterandchainsword.com/topic/242284-the-army-painter-products/
Haven't seen the site myself, but whilst I'm no expert, I wouldn't recommend 'dipping', you're much better off doing it with a brush.
An opinion borne from ignorance.....
No technique is better or worse than another, they simply produce different results. Dipping is an awesome way to achieve a certain look for your army....but you have to remember that it is merely a tool and not a "magic solution" for painting.
Here are some examples of a few models I have dipped;
Pre-Dip
Post-Dip
Post-Clean Up
And a Grey Knight I did
It really irks me when people start classifying one paint style as better than another, or saying that one in bad and one is good.....it shows ignorance in how painting actually works, all the various techniques produce different effects, now based on the type of look you are going for one style or technique might better more applicable than another.....
So as far as dipping goes, it is a great way to achieve a quick finished look. I would suggest the mid-tone, and I would also spend a great deal of time planning out your paint scheme so that the colors you pick are not too dark once the dip has been applied. Also, set your self up for some assembly line work and have all your tools ready to go.
As far as the Army Painter Primers, I really like them, I just recently started using them, I still prime my models white, then add the army painter primer, but that is more of a personal choice than anything. Good luck and let me know if you have any other questions.
Ashton
I have used their spray paints and primers and were happy with them. Normally I just buy my spray paints from the hardware store and have come to the conclusion that spray paint is spray paint. Stay away from anything that says "2X coverage" or "1 coat" sprays because that just means the paint is thick and gloppy. So all in all, the Army Painter primers were just as good as any other.
I have done a dipped army, but not with Army Painter dips. I used minwax tudor, but if you want your own colors, they make a clear acrylic matte you can tint with what ever ink you like. You can get a table ready army together fast that still looks better than half of the "pro painted" stuff you see on ebay, but then that's not saying much. It is basically a heavy wash and protective coating in one step. If you want a "Best Army" look, you will still need to do more work than base coat dip and drybrush.
In any case, while I have not used their dipps, the products I have used from Army Painter have been good and reliable quality so I would think their dip would be as well.
While I can't completely agree with Redfinger, I can see what he is saying. In my opinion, some techniques are just inferior to others, but that is very subjective. At the end of the day, the only person who needs to be happy with the results is you, the owner of the army. Do it how you want to do it, but be open to ideas, and willing to try things. You shouldn't just completely dismiss something because it doesn't fit with your method.
Dipping is just the 'one size fits all' method of applying a Glaze/Wash. Instead of selectively placing Wash where you want it, it goes over the entire model in one massive coat. While it's a very simple method it actually produces a pleasing result, as we've been shown. It's not cheating or inferior, it's just different. I personally prefer the control of placing Glaze selectively, since a dip covers (and thus changes) everything, it's not for me.
Now that you've see what it will actually do, only you can choose if it will suit the look you're going for.
As you say its down to me so based on what you have all said i will try this out and see how i get on with dipping like the look you get. Since i'm a complete beginner i think this might be a good way to get a nice looking army the quickest and get playing!
Thanks one again my brothers!
Chris
It should be noted that Space Marines are one of the best candidates for dipping.
I don't like using dips, but that's because of preference. I've seen Space Marines and Tyranids come out with pretty nice finishes.
An observation: Dipping probably works best with a model that uses mostly analagous colours and sticks to mostly warm or mostly cool. A model that uses a paint scheme of complimentary colours might not be such a good candidate.
When I said "I'm no expert", I think I pretty much established that my opinion was borne from ignorance; so thanks for your pointless diatribe. I just didn't think dipping would be an accurate enough technique to be effective, but it seems you have proved me wrong.
As a side note, if you get the Army Painter superglue, beware that it dries in the tip. When I went to use some new superglue I got from an LGS a couple of days after purchase, I had to remove the top so that I could use the superglue inside (with a toothpick). It was my own fault for not checking, really. :)
As a side note, if you get the Army Painter superglue, beware that it dries in the tip. When I went to use some new superglue I got from an LGS a couple of days after purchase, I had to remove the top so that I could use the superglue inside (with a toothpick). It was my own fault for not checking, really. :P
Keep sewing needles for just such an occasion! Zap-a-Gap used to do that to me all the time. Usually you can chip it out with a sturdy needle that's just a touch smaller than the tip.
@BoldType
How many models, dude?
Not sure about Army Painter specifically, but I can say if you get a high quality Kolinsky Sable brush in general, you'll be happy with it. Windsor & Newton Series 7 is one of the more recognizable brands, and the ones I use, but there are other good ones.
They will cost about 2-to-3 times more then an 'average' brush, but they will perform much better, and if you treat them well, they last for years. I still have my first W&N Series 7 #0 that is 6+ years old, and even though it's missing some bristles, it still has a good tip with no splitting.
