recon0321 Posted November 23, 2011 Share Posted November 23, 2011 i have a idea to use some gloss varnish on parts of my space marines armor to make certain color "pop" more, however i am concerned how can i protect the rest of the model from damaged like chips and dings from playing? would matt varnish over gloss take away the shine? but couldn't do matt varnish over the entire model then put put the gloss on the parts that i want and still get the desired effect? thanks brothers Link to comment https://bolterandchainsword.com/topic/242373-gloss-varnish/ Share on other sites More sharing options...
Subtle Discord Posted November 23, 2011 Share Posted November 23, 2011 Matte or Stain spray, then go back and pick out the areas you want shiny with painted on Gloss. Link to comment https://bolterandchainsword.com/topic/242373-gloss-varnish/#findComment-2930219 Share on other sites More sharing options...
OptiMAT Posted November 23, 2011 Share Posted November 23, 2011 I've found the Satin spray to be great for getting edges and colours to enhance/shine without it going OTT. However, I am looking for a Matte spray now, because while the Satin is good, I personally didn't really like it for the whole of my force. Link to comment https://bolterandchainsword.com/topic/242373-gloss-varnish/#findComment-2930235 Share on other sites More sharing options...
Brother Nihm Posted November 24, 2011 Share Posted November 24, 2011 Matte or Stain spray, then go back and pick out the areas you want shiny with painted on Gloss.This. Link to comment https://bolterandchainsword.com/topic/242373-gloss-varnish/#findComment-2930565 Share on other sites More sharing options...
recon0321 Posted November 24, 2011 Author Share Posted November 24, 2011 I don't wanna sound stupid but what is spray stain Link to comment https://bolterandchainsword.com/topic/242373-gloss-varnish/#findComment-2930832 Share on other sites More sharing options...
Subtle Discord Posted November 24, 2011 Share Posted November 24, 2011 "There are no stupid questions." ... *Billy raises his hand* ... "Except from you, Billy." ... *Billy lowers his hand* ~ Family Guy (If memory serves correct) If you're not sure, it's not a stupid question. Matte is dull and flat. Gloss is shiny and 'wet'. Satin is between the two. It's called Semi-Gloss sometimes, but Satin (very much like the fabric, hence the name) is more accurate. Now, if that's the look you want is completely subjective, and you need to decide. On a semi-related note; Gloss generally will also protect a miniature better than Matte. Satin also sits in the middle in that case as well, more protection than Matte with less shine than Gloss. Do a light cover of Gloss and a light cover of Matte or Satin to get best ob both worlds, but be very careful not to put too much on. Since it's transparent, varnish can be tricky to know when it's done. I personally will brush some Gloss varnish on to things that are prone to wear (Horn tips, bayonet tips, exposed edges) and then follow with a Satin spray, to avoid applying too much. Link to comment https://bolterandchainsword.com/topic/242373-gloss-varnish/#findComment-2930848 Share on other sites More sharing options...
Hemal Posted November 25, 2011 Share Posted November 25, 2011 gloss then satin or matte is your firend for the reasons listed above. Gloss also helps decals adhere properly... Link to comment https://bolterandchainsword.com/topic/242373-gloss-varnish/#findComment-2931306 Share on other sites More sharing options...
IdOfEntity Posted November 25, 2011 Share Posted November 25, 2011 Another option is to use brush on matte and brush on gloss varnish. You can pick out the areas you want to shine without adding layer upon layer on top of your detail work. Link to comment https://bolterandchainsword.com/topic/242373-gloss-varnish/#findComment-2931349 Share on other sites More sharing options...
