eudean600 Posted November 30, 2011 Share Posted November 30, 2011 what is the best way or best chemical to use to strip paint of a model i have some terminators that need stripping and re painting as ive messed um up big time haha Link to comment https://bolterandchainsword.com/topic/242727-stripping-models/ Share on other sites More sharing options...
Doghouse Posted December 1, 2011 Share Posted December 1, 2011 If you are in the UK Fairy Power Spray is the best stuff that I've come across and is readily available. If you are in the states or outside the UK then Simple Green seems to be the stripper of choice. You can also use brake fluid although the fumes put me off touching that stuff. The first two are probably the safest methods. Link to comment https://bolterandchainsword.com/topic/242727-stripping-models/#findComment-2934832 Share on other sites More sharing options...
Grizzly_bear Posted December 1, 2011 Share Posted December 1, 2011 Or detol...that's works a treat too Link to comment https://bolterandchainsword.com/topic/242727-stripping-models/#findComment-2934855 Share on other sites More sharing options...
Olis Posted December 1, 2011 Share Posted December 1, 2011 Or detol...that's works a treat too That it may do, but it stinks and it's preferable to wear gloves when using it. Both downsides the Power Spray doesn't have (in fact, the Spray has quite a nice smell to it). Link to comment https://bolterandchainsword.com/topic/242727-stripping-models/#findComment-2934956 Share on other sites More sharing options...
sp4rky Posted December 2, 2011 Share Posted December 2, 2011 Put me down on the side of Fairy Power Spray. Water it down in a tub and drop your models in there for a few hours, then gently rub with a cloth of some sort (or a toothbrush). Link to comment https://bolterandchainsword.com/topic/242727-stripping-models/#findComment-2935706 Share on other sites More sharing options...
