Nemesis Dreadknight on a 60mm base
I've been struck with an idea for a most impractical and expensive conversion involving a Nemesis Dreadknight.
However since after I'm done with it it won't count as a dreadknight, and I want it to be semi-legit, I want to put it on a dreadnought-sized (60mm) base. Question is, will it fit? Or does it have too much of a "wide stance"?
Mine IS on a 60mm base.
Its stance is unmodified and it barely fits.
There is a corresponding 60mm socket on its large base where he slots in during play (there is shrubbery and gubbins on the big base, and it gets used as a small copse of trees (terrain) when not being used for the big guy (single large tree on a 60mm base fits into the slot to fill it in that case).
Makes it easier to pack it away, also. Both fit into a 3"tall tray, this way.
