pueriexdeus Posted December 20, 2011 Share Posted December 20, 2011 Hi folks, I'm a n00b in DowII. Playing the Campaign, in the first defensive scenario My dilemma is choosing the three select squads that will deploy with me. I can not drag and drop the units into the necessary place. I have no idea where the place is, and right clicking the chosen squad does not allow me to drag it anywhere. So what am I missing? I would appreciate some forum assistance. Thanks Link to comment https://bolterandchainsword.com/topic/243797-dow-ii/ Share on other sites More sharing options...
No Foes Remain Posted December 20, 2011 Share Posted December 20, 2011 Up on the top left hand corner of the screen there will be three icons (IIRC) click the one with the drop-pod shape on it and you should be able to drap and drop them from there. Link to comment https://bolterandchainsword.com/topic/243797-dow-ii/#findComment-2947805 Share on other sites More sharing options...
Lord Mad Balrog Posted December 21, 2011 Share Posted December 21, 2011 If you're only on the first few missions of the campaign, you won't have enough hero units to switch out. (Three or fewer.) You have to have four before it gives you the option to switch them out. If you do have four, then make sure the storyline hasn't called one of them away for one reason or another (as it will sometimes do). If the Captain's advice still doesn't work after you've tried all this, then... Well, it sounds like you should learn to love the squads you have. (Note that you must take the Commander/Hero's Hero unit on every mission. If you're trying to switch him out, you can't.) Link to comment https://bolterandchainsword.com/topic/243797-dow-ii/#findComment-2948318 Share on other sites More sharing options...
pueriexdeus Posted December 21, 2011 Author Share Posted December 21, 2011 Up on the top left hand corner of the screen there will be three icons (IIRC) click the one with the drop-pod shape on it and you should be able to drap and drop them from there. Thanks I'll give it a try. *edit* Tried it and discovered the problem. I am using three 22" widescreen monitors in SLI at 4800x1040 When I click on the Drop-pod my Units disappear, they are moving from the far right monitor and hiding under a black space on the far left monitor. I have discovered that the only way to accomplish loading my squads if by first lowering my settings to 1920x1080, effectively using only the center monitor, doing what needs to be done, and then advancing my settings to play on all three screens. Any ideas on a fix for this? Link to comment https://bolterandchainsword.com/topic/243797-dow-ii/#findComment-2948357 Share on other sites More sharing options...
No Foes Remain Posted December 21, 2011 Share Posted December 21, 2011 Personally no, I only use my laptop for gaming so only one screen. Other members might know about using more than one monitor for gaming, the only thing I can think that mighht fix it is to adjust the in-game screen resolution until you can see all the whole screen on all three monitors. Link to comment https://bolterandchainsword.com/topic/243797-dow-ii/#findComment-2948613 Share on other sites More sharing options...
Warlord_Gorgutz Posted January 7, 2012 Share Posted January 7, 2012 Hi folks, I'm a n00b in DowII. Playing the Campaign, in the first defensive scenario My dilemma is choosing the three select squads that will deploy with me. I can not drag and drop the units into the necessary place. I have no idea where the place is, and right clicking the chosen squad does not allow me to drag it anywhere. So what am I missing? I would appreciate some forum assistance. Thanks What squads DO you have? Link to comment https://bolterandchainsword.com/topic/243797-dow-ii/#findComment-2960848 Share on other sites More sharing options...
