maturin Posted January 4, 2012 Share Posted January 4, 2012 actually it does tell you to ignore it, maturin. thats how the disembark section starts out doesn't it? it says "you cannot disembark within 1" of an enemy model". it then says if enemy models are preventing you from disembarking, you may make an emergency disembark and place your unit anywhere within 2" of the hull....well if what your saying is true it would say "anywhere within 2" of the hull, as long as its not within 1" of the enemy", wouldn't it? i find it kind of odd that it would lead with "you can't disembark within 1" of the enemy" and then continue to say if you can't do this, you can emergency disembark anywhere within 2" of the hull. to me that is cut and dry. The rulebook does make some assumptions about using standard English, and does not assume that they need to spell out and re-spell out all exceptions to the rules in every possible case. See dswanick's response to SeattleDV8 in the two posts above: dswanick points out the open-topped embarkation/disembarkation rules are for regular embarkation and disembarkation, where the 1" rule presumably still applies even though it is not specifically restated. Otherwise by your interpretation, KnowThyEnemy, you could disembark off of opentopped transports within 1" of enemy models (see SeattleDV8's post). I don't see why having both rules apply is so counterintuitive. You can have an enemy squad preventing exit from a chimera's rear hatch thanks to the 1" rule - so the squad ED's and gets off at the front. The 1" rule is still in effect but the ED rule has prevented destruction of your unit. That's why GW inserted the rule into 5th ed. presumably. I'll reiterate that my view is supported by the rules - in the very next sentence after the ED rule is laid out, the rulebook states "If even this disembarkation is impossible...." (emphasis mine). The rules reiterate that it is a disembarkation, and presumably subject to the regular rules of disembarkation. (Though this is where dswanick and I disagree). Link to comment https://bolterandchainsword.com/topic/243829-emergency-disembarkation/page/6/#findComment-2958842 Share on other sites More sharing options...
dswanick Posted January 5, 2012 Share Posted January 5, 2012 I'll reiterate that my view is supported by the rules - in the very next sentence after the ED rule is laid out, the rulebook states "If even this disembarkation is impossible...." (emphasis mine). The rules reiterate that it is a disembarkation, and presumably subject to the regular rules of disembarkation. (Though this is where dswanick and I disagree). Yeah, and mostly on an interpretational issue. - maturin (as I understand it) sees "If even this disembarkation is impossible" and interprets it to mean that ED is a subset of nD (normal Disembarking) and therefore beholden to all the rules of nD. - I see "If even this disembarkation is impossible" and iterpret it to mean that ED is a seperate rule from nD and only beholden to its own explicitly stated rules (this disembarkation{ED} as opposed to that disembarkation{nD}). Isn't Rules as Interpreted fun. :lol: Unfortunately, these kinds of issues can almost never be resolved. Unless some new bit of information comes to light (or GW releases a clear and pertinent FAQ). So with that, guys, I thank you for the good debate on this. Even if no opinions have been changed about the rule, we are at least all much better informed on all the pertinent RAW and RAI and can better make our case in any future disputes on this issue. Link to comment https://bolterandchainsword.com/topic/243829-emergency-disembarkation/page/6/#findComment-2958952 Share on other sites More sharing options...
maturin Posted January 5, 2012 Share Posted January 5, 2012 I agree 100%. :mellow: Link to comment https://bolterandchainsword.com/topic/243829-emergency-disembarkation/page/6/#findComment-2959009 Share on other sites More sharing options...
falldown Posted January 5, 2012 Author Share Posted January 5, 2012 Makes me sad that we don't have a definitive solution, but I truly appreciate the debate and effort everyone put into this. Guess it is "dice-off/most important rule" territory if it comes up on the table. Link to comment https://bolterandchainsword.com/topic/243829-emergency-disembarkation/page/6/#findComment-2959411 Share on other sites More sharing options...
thade Posted January 5, 2012 Share Posted January 5, 2012 <3 Link to comment https://bolterandchainsword.com/topic/243829-emergency-disembarkation/page/6/#findComment-2959473 Share on other sites More sharing options...
Something Wycked Posted January 5, 2012 Share Posted January 5, 2012 <3 Translation: You guys are awesome, and make me happy to be part of the B&C. :huh: Link to comment https://bolterandchainsword.com/topic/243829-emergency-disembarkation/page/6/#findComment-2959492 Share on other sites More sharing options...
