AngryJohnny Posted December 23, 2011 Share Posted December 23, 2011 I have what may be a stupid question: I'm taking a Captain w/TDA & a pair of Lightning Claws and I have 5pts left over in my list. What I want to know is can I add Melta-Bombs to my Captain in TDA? Thanks in advance. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/ Share on other sites More sharing options...
JamesI Posted December 23, 2011 Share Posted December 23, 2011 No, meltabombs are not an option for Terminator armored characters. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2950284 Share on other sites More sharing options...
shortysl Posted December 23, 2011 Share Posted December 23, 2011 Sad, but true. Just make sure he's part of a squad that has at least one Power Fist/Thunder Hammer in it and you'll have little trouble with vehicles. Failing that, remember that, in an assault you always strike the rear armour of any vehicle that doesn't have a Weapon Skill, so your Captain can still damage most vehicles if you're in a tight spot. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2950300 Share on other sites More sharing options...
Grey Mage Posted December 24, 2011 Share Posted December 24, 2011 That being said, while they are not normally an option there is nothing in the rules for TDA that says they cant be used if they do have the option- for example, terminators in planetstrike can end up having assault, defensive, and meltabombs. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2950466 Share on other sites More sharing options...
Morollan Posted December 24, 2011 Share Posted December 24, 2011 Sad, but true. Just make sure he's part of a squad that has at least one Power Fist/Thunder Hammer in it and you'll have little trouble with vehicles. Failing that, remember that, in an assault you always strike the rear armour of any vehicle that doesn't have a Weapon Skill, so your Captain can still damage most vehicles if you're in a tight spot. I wouldn't rely on the ability to glance (on a 6) against only the weakest vehicle armour. If he's up against a vehicle, especially a walker, then the captain will need some help. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2950610 Share on other sites More sharing options...
shortysl Posted December 24, 2011 Share Posted December 24, 2011 Sad, but true. Just make sure he's part of a squad that has at least one Power Fist/Thunder Hammer in it and you'll have little trouble with vehicles. Failing that, remember that, in an assault you always strike the rear armour of any vehicle that doesn't have a Weapon Skill, so your Captain can still damage most vehicles if you're in a tight spot. I wouldn't rely on the ability to glance (on a 6) against only the weakest vehicle armour. If he's up against a vehicle, especially a walker, then the captain will need some help. Very true, which is why i mentioned it in tight spots only. Most definitely the best option would be to have him accompanied by a unit that includes tank busting kit, but i'm just trying to offer some advice. I used to run a Company Master with Twin Lightning Claws in Power Armour and although i could've given him Meltabombs, i just made sure his Command Squad included a Power Fist instead. Never needed to use the Krak Grenades that the squad come with. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2950625 Share on other sites More sharing options...
Sir Blayse Posted December 24, 2011 Share Posted December 24, 2011 Terminators don't have any grenades at all. Also, Krak's are str 6, so they glance most on 4's. Frag's are strength 4, but no one would use those to bust armor. Not sure if it makes it legal, but Army builder let's you buy Melta bombs for special characters, like chaplains, captains, and priests... even those in TDA. But, I usually don't waste the points buying those for units that will either have powerfist or Thunderhammers attached. Or libby with Sanguine Sword. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2950712 Share on other sites More sharing options...
Khorneeq Posted December 25, 2011 Share Posted December 25, 2011 I think I'll have to disagree. I know that fluffwise models in Terminator armour don't use grenades of any type, but current codex entry makes it possible. Characters are given a list of Wargear that they replace for terminator armour, but melta bombs are outside of this list. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2951165 Share on other sites More sharing options...
shortysl Posted December 25, 2011 Share Posted December 25, 2011 I think I'll have to disagree.I know that fluffwise models in Terminator armour don't use grenades of any type, but current codex entry makes it possible. Characters are given a list of Wargear that they replace for terminator armour, but melta bombs are outside of this list. Now I could easily be wrong here but i believe the armoury lists are set up in such a manner that, when you pick Terminator Armour for a character, you're only then able to select wargear for that character if it is in the list that follows the option for Terminator Armour. Melta Bombs and equipment such as pistols are all available before the option for Terminator armour, are they not? Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2951169 Share on other sites More sharing options...
Khorneeq Posted December 25, 2011 Share Posted December 25, 2011 Melta bombs are listed before Termy armour, but: - You take Melta Bombs - You Replace PA, boltgun, frags and kraks for Terminator Armour It says nowhere that You loose Melta Bombs While doing so :huh: Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2951171 Share on other sites More sharing options...
shortysl Posted December 25, 2011 Share Posted December 25, 2011 Melta bombs are listed before Termy armour, but:- You take Melta Bombs - You Replace PA, boltgun, frags and kraks for Terminator Armour It says nowhere that You loose Melta Bombs While doing so ;) I see your point. This must be a Rules As Written vs. Rules As Intended moment :huh: I personally wouldn't do it but as you say, nowhere does it say that you can't. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2951174 Share on other sites More sharing options...
Xenith Posted December 25, 2011 Share Posted December 25, 2011 It says nowhere that You loose Melta Bombs While doing so ;) I see your point. This must be a Rules As Written vs. Rules As Intended moment B) I personally wouldn't do it but as you say, nowhere does it say that you can't. RAI went out the window with the GK codex when Mat Ward let models in TDA use grenades (Techmarine?) Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2951225 Share on other sites More sharing options...
AbusePuppy Posted December 26, 2011 Share Posted December 26, 2011 Terminators in the Daemonhunter codex were allowed to use grenades as well. The only "precedent" that Terminators couldn't was the fact that GW rarely, if ever, gave Terminators grenades as part of their basic equipment. It has never been stated or implied that they were unable to use them. Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2951468 Share on other sites More sharing options...
Xenith Posted December 26, 2011 Share Posted December 26, 2011 Terminators in the Daemonhunter codex were allowed to use grenades as well. The only "precedent" that Terminators couldn't was the fact that GW rarely, if ever, gave Terminators grenades as part of their basic equipment. It has never been stated or implied that they were unable to use them. Sorry AP: The precedent lies in 3rd ed marine codexes of all flavours - Models in TDA were only allowed to purchase items from the armoury marked with an asterisk. Grenades, pistols etc were not asterisked, so expressly forbidden for use by those in TDA ;) Link to comment https://bolterandchainsword.com/topic/244035-tda-melta-bombs/#findComment-2951771 Share on other sites More sharing options...
