Powders?
Never heard them called "distressing poweders" but there are plenty of places to pick them up though here in the states....but as I say, "The cheap is expensive" IMO weathering powders are not something to go cheap on. The lower end brands tend to have binding agents in them like carnuba wax. This wax can have poor reactions with paints and finishes resulting in blotchy and not very nice looking results. Whatever brand you go with makes sure it is pure pigment with no additives, this will provide the most versatility and enable you to achieve the best results. I bought mine from secretweaponminatures, they were local to me in Sacramento when I lived there.
Ashton
https://bolterandchainsword.com/topic/244306-powders/#findComment-2953401
I made my own using chalk pastelles that I ground up using a kitchen sieve, lol.
They worked really well, although some of the grains were a but big.
The advantage is that you can mix up your own colour variants, I made mine very similar to Forgeworlds and stored them in some old flock tubs.
https://bolterandchainsword.com/topic/244306-powders/#findComment-2953756
Use a coarse grit sand paper to make the dust, and you can avoid the problem with the 'grains'. It takes a lot of work to make a large amount, but you can also just make what you needs as you go. I've had very good results doing this with good quality conté sticks. Leave them as sticks (the large range of colours is a bonus) and grind up enough for your current project.
MiG and Vallejo are great pre-made products, and will perform well. As has been said, just be sure to use a product intended for model and miniature weathering. They will produce the best results.
https://bolterandchainsword.com/topic/244306-powders/#findComment-2954164
I made my own white, black, and rust powders by getting artist's charcoals and scraping off the amount that I need for the job. They work well just brushed on and fixed (with hair spray), or when mixed with rubbing alchohol.
They are very cost effective as well.
Cheers,
https://bolterandchainsword.com/topic/244306-powders/#findComment-2954580
