AlanofAngels Posted January 1, 2012 Share Posted January 1, 2012 So I'm currently working on my FT strike force, and I had a bit of an idea. I'm sure it has been done before, but the general idea is to have my squads composed of marines from seperate squads. Everything would remain normal, but I thought I would put different squad numbers on each marines shoulder pad. Meaning in Alpha squad I could have marines originally from something like 3rd, 5th, and 6th squads, but after some sort of unsuccesful orbital attack or somesuch, had survivors of remaining squads re assigned. So my question is, would it look wierd to have several different numbered shoulders in 1 squad? Especially if one didnt know the background? I'm not sure if I'll do it, but it was just an idea. Anywho, ideas greatly welcomed cause I'm pretty on the fence! :tu: Link to comment https://bolterandchainsword.com/topic/244491-flesh-tearer-question/ Share on other sites More sharing options...
Leonaides Posted January 1, 2012 Share Posted January 1, 2012 As long as both you and your opponent can still tell fairly easily which models are in which squads... Link to comment https://bolterandchainsword.com/topic/244491-flesh-tearer-question/#findComment-2955712 Share on other sites More sharing options...
Grimdarkness Posted January 1, 2012 Share Posted January 1, 2012 Would the chapter even bother numbering there armour since there are so few of them there more then likely to move around a lot during deployments any way. If I was to do it I'd use small numbers. Link to comment https://bolterandchainsword.com/topic/244491-flesh-tearer-question/#findComment-2955720 Share on other sites More sharing options...
SamaNagol Posted January 1, 2012 Share Posted January 1, 2012 They don't number their squads anymore I don't think Link to comment https://bolterandchainsword.com/topic/244491-flesh-tearer-question/#findComment-2955760 Share on other sites More sharing options...
Vodunius Posted January 1, 2012 Share Posted January 1, 2012 The Flesh Tearer example in the codex has a red drop and tactical arrow on the shoulderpad and a 2 on his kneepad ~ I figured the drop was the company and the 2 was the squad number. I see no logical reason why they would retain the tactical marking but do away with the squad number, whilst the opposite would make a lot of sense. Addendum: it would make sense to ditch the number and keep the tactical marking if they had kept all companies active with only one squad of each type in each company, but we know they didn't do that. Link to comment https://bolterandchainsword.com/topic/244491-flesh-tearer-question/#findComment-2955772 Share on other sites More sharing options...
