Forté Posted January 3, 2012 Share Posted January 3, 2012 Siege shield or not? I can see the shield being of some use but at the same cost as an extra Grey Hunter.....is the shield really worth it? Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/ Share on other sites More sharing options...
Res Ipsa Loquitur Posted January 3, 2012 Share Posted January 3, 2012 No, it's not worth it at all. IMO, of course. Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957717 Share on other sites More sharing options...
Gen. Confusion Posted January 3, 2012 Share Posted January 3, 2012 Use the dozer blade instead. It is very cheap. Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957783 Share on other sites More sharing options...
Karack Blackstone Posted January 3, 2012 Share Posted January 3, 2012 The same cost as a Grey Hunter to totally ignore difficult terrain, compared with one-third the cost of a Grey Hunter to reroll the Dangerous Terrain test. Sometimes, investment does return better than put in. If you're points pinching, consider carefully that you can't get bogged down with the Siege Shield; you potentially can with just a Dozer Blade. Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957785 Share on other sites More sharing options...
G. A. K. Posted January 3, 2012 Share Posted January 3, 2012 the shield is only 10 points, not 15. I use it all the time, with extra armor too! you move into some cover cuz your going to shoot and not pop smoke unless your stunned. G Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957811 Share on other sites More sharing options...
Forté Posted January 3, 2012 Author Share Posted January 3, 2012 the shield is only 10 points, not 15. I use it all the time, with extra armor too! you move into some cover cuz your going to shoot and not pop smoke unless your stunned. G Very fair points there. Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957816 Share on other sites More sharing options...
Grey Mage Posted January 3, 2012 Share Posted January 3, 2012 Mine is removable, solves all these problems. Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957855 Share on other sites More sharing options...
Forté Posted January 3, 2012 Author Share Posted January 3, 2012 Mine is removable, solves all these problems. How'd you manage that? Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957861 Share on other sites More sharing options...
Grey Mage Posted January 3, 2012 Share Posted January 3, 2012 Simple, I built and painted it but didnt glue it on. It has little holes it pops right into and out of without a problem as long as your gentle. Ive seen others done with magnets. Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957890 Share on other sites More sharing options...
Forté Posted January 3, 2012 Author Share Posted January 3, 2012 Ok. Makes sense. Best way to go then, cheers. Link to comment https://bolterandchainsword.com/topic/244642-urgent-vindicator-based-question/#findComment-2957898 Share on other sites More sharing options...
