Golf33 Posted January 8, 2012 Share Posted January 8, 2012 ... I wasn't going to use them as Neophytes, without a bit of work. 1st was fixing the heads. The 'Iceman' haircuts might have been cool when Top Gun came out, but they are hardly in character for BTs. So all the models got a haircut, back to stubble or at least a crew cut. Next, a couple of Neophytes either grew a nice middle-ages bowl haircut or a tonsure - all the warrior monks these days are wearing those. Since we're big on heraldry (our own, rather than the Aquila) and Neophytes want to be just like Initiates when they grow up, we needed some space to paint said heraldry. That means at least half a surcoat per Neophyte! This meant shaving off the chestplate Aquila and putting some greenstuff on instead. I have tried to match the folds to the poses as far as possible. The rest of the half-surcoat was also greenstuffed, the best way turned out to be rolling out a flat sheet of the stuff bigger than what was needed, letting it cure most of the way then fitting it to the legs and belt with a bit of overlap all around. Once fully cured I could trim down the edges to the correct size and shape and then add folds by putting on more greenstuff. http://farm8.staticflickr.com/7020/6604769763_e86cdd09b9_o.jpg In a month or so I should be able to start on some more - next time I'll take some work-in-progress shots to illustrate the process. Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/ Share on other sites More sharing options...
philsminions Posted January 8, 2012 Share Posted January 8, 2012 Those look fantastic brother! I have yet to delve into playing with green stuff...might be a good time to purchase some and play around with it. Please keep us updated as they're finished...love to see the final product. Great work, very natural! Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2961488 Share on other sites More sharing options...
Trignama Posted January 8, 2012 Share Posted January 8, 2012 Is working with GS difficult? Im assuming you have some sort of talent to do it. Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2961499 Share on other sites More sharing options...
Eliath Posted January 8, 2012 Share Posted January 8, 2012 ya know...if i could make neophytes look like this, I'd actually use them. Hah. Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2961507 Share on other sites More sharing options...
Olis Posted January 8, 2012 Share Posted January 8, 2012 They look good, you done a good job Templarifying them. @ Trignama & Eliath - Maybe this thread might help, brothers. :devil: Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2961511 Share on other sites More sharing options...
Firepower Posted January 8, 2012 Share Posted January 8, 2012 Well...with my neopthytes, I simply put an SM helmet on top of the scout model and used basic assault arms. If I could pull off this sort of GS work convincingly (and believe me, I've tried) I would do this in a heartbeat. Everything seems to be off to a stellar start to me. Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2961527 Share on other sites More sharing options...
twofour878 Posted January 9, 2012 Share Posted January 9, 2012 Wow those are exactly the kind of thing I wanted to do to my neophytes but lacked the confidence to do for now. I tried putting tabards on a couple spare terminator bodies I had lying around and it went horribly wrong (luckily I had some gaps that needed filling so the GS didn't go to waste). Nice job. Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2962118 Share on other sites More sharing options...
Acunnon Posted January 9, 2012 Share Posted January 9, 2012 very nice brother, simple functional and very fitting. Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2962405 Share on other sites More sharing options...
Castellian Payens Posted January 9, 2012 Share Posted January 9, 2012 Now only if we all could be tht good with green stuff ;) Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2962422 Share on other sites More sharing options...
T14 Posted January 9, 2012 Share Posted January 9, 2012 Looking good. :P I have a similar dilemma, except I can find no redeeming feature in the scout models at all. I will in all likelyhood end up using cenobyte servitor models instead (they are technically still neophytes, even if their training has somewhat ended). This will give me the opportunity to field all the devotional "critters" that seem to be following our dark knights wherever they go. -T14 Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2962447 Share on other sites More sharing options...
Eberious Posted January 9, 2012 Share Posted January 9, 2012 They look good, might add some to mine but I'm in the mind frame of they havent earned the right to wear tabards yet. Plus the Chapter keeps taylor servitors only make sizes to fit power armour. I found some heads from WHF (mainly Empire) really work with neos. Link to comment https://bolterandchainsword.com/topic/244928-neophytes-from-space-marine-scouts/#findComment-2962468 Share on other sites More sharing options...
