Painting for Noobs.
Yep, all GW/Citadel miniatures come unpainted. For undercoating, black for a darker look, white for lighter, such as yellows. To thin paints, I put a blob of paint on my palete then dip my clean brush in water and mix the paint on the palete (some people just add a small amount of water to the pot). We thin paints to help them go on smoothly and prevent streaking/brush marks in the finished paint job. As for painting techniques, for a beginner, dry-brushing is a quick and easy highlighting technique. Basically once you've done your base coat, we'll choose boltgun metal on a boltgun, you then get a lighter colour, either chainmail or mithril, then after dipping your brush into the paint, wipe MOST of it off again then lightly brush over the boltgun. What this achieves is leaving the darker colour in the recesses while lightening the outside. Once dry this is usually followed by a wash of some kind, badab black in this case, to blend the two colours better. Dry-brushing can be used for just about any colour in GWs range. As for brushes, one detail, one normal, one tank brush. Just head to GW and they'll sort you out.
Cheers,
Jono
Okay, hypothetical question.
I want to start out with one squad of Grey Knights. So, I woud base coat them black, or white? After that dries, Main coat them in Mithril Silver, and do all the highlights in gold. are two colors to few, or will that be enough to give them real detail. If not, what other colors would be good? I figured on a medium brush, and a fine detail brush.
Sorry for the cluelessness, but I have only just decided to get into 40k
A wash is a very watered down paint (think ink) that darkens the colour without completely covering it, it mostly gathers in the recesses of the models details. It is a quick and easy way to add natural shading to a miniature.
Cheers,
Jono
As an after thought, if you live near a GW, they will let you open your box instore and show you how to paint using their paints and equipment. I did this when I was starting out and found it to be a massive help, the GW guys really can help.
