Brother Uriel Sanguis Posted January 19, 2012 Share Posted January 19, 2012 Hail Brothers, or should I say, Wolf Brothers though I am a Black Templar of the Black Templars Subforum would it be common courtesy to hlep out with a fellow Brother? I have thought once about doing Space Wolves before don't get me wrong the wolves just grab my attention on the rim of my vision. True Vikings and true honoured Barbarians! However, I prefer to be more knightly and follow chivalry.... Moreover! I am asking this of your subforum because I am doing a Winter Crusade, do you have any help or tutorials on doing winter-based 25mm Bases with Army Painter Snow? Thank you! Hail the Emperor, Dorn, and Russ! Link to comment https://bolterandchainsword.com/topic/245687-frosty-25mm-bases/ Share on other sites More sharing options...
Russ Brother 92 Posted January 19, 2012 Share Posted January 19, 2012 This might help - although it's for ice bases: - or try this: Link Otherwise I'm not sure chap, hopefully an elder like Gray Mage will appear with words of wisdom :) Link to comment https://bolterandchainsword.com/topic/245687-frosty-25mm-bases/#findComment-2971735 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted January 19, 2012 Share Posted January 19, 2012 That Ice Base tutorial is amazingly AWESOME!! I will be looking for casting resin today!! Thanks for the awesome links Russ Brother 2!! Good luck Uriel, I hope these links provide you with what you are looking for, or at least somebody here posts something for you!! End of Line Link to comment https://bolterandchainsword.com/topic/245687-frosty-25mm-bases/#findComment-2971915 Share on other sites More sharing options...
Russ Brother 92 Posted January 20, 2012 Share Posted January 20, 2012 That Ice Base tutorial is amazingly AWESOME!! I will be looking for casting resin today!! Thanks for the awesome links Russ Brother 2!! Good luck Uriel, I hope these links provide you with what you are looking for, or at least somebody here posts something for you!! End of Line Rhapsody - this is the resin he used in the vid: Resin Link It's a pleasure, found it in one of the tutorials on here. Link to comment https://bolterandchainsword.com/topic/245687-frosty-25mm-bases/#findComment-2971934 Share on other sites More sharing options...
