Grey hunter ratio
rapscallion
I tend to go with 2 or 3 at 1,000, depending on my list, 3 at 1,500, and 4 at 2,000. That gives you a nice number of highly effective scoring units that can do almost anything. Also, I recommend sticking one squad in a drop pod, as it greatly enhances your number of options. You can drop in and melta a target, camp an objective, ignore the pod and use it to block, provide support to a critical area, and so on.
Yeah, I think 3, 4, 5 would be ideal at those point levels. I don't have enough models to run five full GH units, so it's usually maxed out at four.
As I see it you're the only oen to actually say "how many Grey Hunters" as opposed to GH packs...
For the guys who've posted how many packs you run, how many GH per pack?
QFT! i LOL'ed a bit at the idea of a 2000pts list with only 6 grey hunters! perhaps a great challenge eyes? :)
At 500 2 x @5-6 Melta And Wolf Standard(WS) Rhino
At 1000 2 x @9 in Rhinos with Wolf Guard Pack Leader Combi-Melta Power weapon (PW) or Power Fist (PF) . Melta And WS
At 1500 3 x @9 in Rhinos with Wolf Guard Pack Leader Combi-Melta PW or PF . Melta And WS
At 2000 4 x @9 in Rhinos with Wolf Guard Pack Leader Combi-Melta PW or PF . Melta And WS
At 2k + 2 x Drop Pod @9 in Rhinos with Wolf Guard Pack Leader. Melta And WS
4 x @9 in Rhinos with Wolf Guard Pack Leader. Melta And WS
When I say one per 500pts I mean one ten man pack, with transport or with a WG Pack Leader if theyre footslogging.
The only times Ill run partial packs of GHs is if Its an awkward point value like 1250 or 1750, where Ill sometimes do a single five man pack in a razorback if Im running mech, or if Im playing cityfight... where 5+TDA tends to be my rule.
QFT! i LOL'ed a bit at the idea of a 2000pts list with only 6 grey hunters! perhaps a great challenge eyes? :blink:
Hehe ^_^
Illegal too unless you take Logan or Canis
I have actually played against a 2000 pts canis list which did have that sort of number GH's. Pretty much Annihilation or nothing :D but fun.
I like having a lot of troops just my style
Probably would've been good to mention numbers. These are all nine man squads and a wolf guard, except the Rune Priest's squad, which is eight man. They've all got meltas, standards, Wulfen, and fists, and the Wolf Guards have Combi-Meltas and fists.
Wow i take a very different approach from all of you. At 1000 and 1500 point games i only take 3 5-man squads with a melta in each. they are accompanied by a rune priest each and are all in rhinos. they are a relatively survivable scoring unit being in a rhino and with storm caller cast by one of my rune priests gives all the rhinos a cover save. i do find against marines i need more bodies so i will assault with 2 units but this setup at 1500 points is supported by three long fang squads so the units they charge are rarely at full strength.
It depends a lott on your list and for the role you use them. If you use them like shock troops you need more then if you use a small 6 man unit with a wolf guard sitting in an MSU Razorback/long fang list.
I would recomend to have so many you are not afraid of using them to get killed.
caledonian uprising
You know who you're playing in round 1? I found that there's someone running blob Guard and is drawn with Josh Roberts.
At 1750 - 1850 I'm looking at a minimum of 5 and typically 6 although there's a tourney coming up and my list is due in 45 minutes and I'm still mulling over how many to take. They're usually in blocks of 8 unless its Razorspam when I'll run 6-man units.
I go with a Minimum of 1 per 500pts, with one or two support elements per 500pts- wich includes HQs most of the time.
Sometimes I go heavier, but not often... though it is rounding up.
I used to be a bit light on troops but after losing one too many objective missions I use a similar formula.
I would have to support Grey Mage on this. I woud say 1 pack per 500pts. That pack, at least for me, should be either 9 and a wolf guard and goodies, or a maxed out 10 with goods and two specials. All depending on what roll that pack is goin to perform. I tend to use the 9 plus wolf guard and have the wolf guard armed with a fist or the like to take advantage of the 2 attacks and te bonus to leadership doesn't hurt either. Since my dice tend to go on bouts of hating me.
750 pts: 8 GH(motw, PF/meltagun and WS)1WG(FW,combi-melta) and rhino.
1000 pts: 2x 8(or 9 depending on how many HQ's) GH(motw, PF/meltagun and WS)1WG(FW,combi-melta) and rhino.
1250 pts: 3x 8(or 9 depending on how many HQ's) GH(motw, PF/meltagun and WS)1WG(FW,combi-melta) and rhino.
1500 pts: 3x 8(or 9 depending on how many HQ's) GH(motw, PF/meltagun and WS)1WG(FW,combi-melta) and rhino.
1750 pts: 4x 8(or 9 depending on how many HQ's) GH(motw, PF/meltagun and WS)1WG(FW combi-melta) and rhino.
in 1000 pts i some times use 2 HQ's from 1250 pts i have 2 hq standert.
ussually 1 rune priest and 1 wolf priest
in case of tank based battels, use half the rinos and the others als razorback's
Considering we have the best 15 point standard trooper in the game, it makes sense that a space wolf list would consist of a higher number of grey hunters than standard marine lists.
500 2 X 8GH units.
1000 3 X 8GH units
1500 2X10 1X8 and 1X5
2000 2x10 2X8 and 1X5
Objective grab missions and victory point missions are the most common in tournaments and being able to lose a unit or two and still hold the majority of objectives is a pretty solid tactic for wolves.
When it comes to victory point games wiping out an entire unit of Grey Hunters is not that easy if you play them right, so a larger number of GH units keeps your enemies victory point total low.
Vrox.
