ron Posted January 27, 2012 Share Posted January 27, 2012 If there was ever a place to share a tutorial on how to fix bolter gun barrels (and this works for bolt pistols, heavy bolters and storm bolters too), this is it. The whole thing is up on my blog and is fairly easy to do along with requiring very little in terms of equipment. Nothing most hobbyists don't already have on their desks. You can see the whole tutorial here. Link to comment https://bolterandchainsword.com/topic/246185-how-to-fix-damaged-gun-barrels/ Share on other sites More sharing options...
Olis Posted January 27, 2012 Share Posted January 27, 2012 -_- Holy hairy moses. That's so simple. It's one of those things where you wonder why you hadn't thought of it yourself. Thankyou! Link to comment https://bolterandchainsword.com/topic/246185-how-to-fix-damaged-gun-barrels/#findComment-2978672 Share on other sites More sharing options...
Lord Ragnarok Posted January 27, 2012 Share Posted January 27, 2012 Yeah, this is a forehead smacker for sure. I've GS'd the broken part but never thought to roll my own barrel... *Sigh*. That said, what is your rolling technique? Link to comment https://bolterandchainsword.com/topic/246185-how-to-fix-damaged-gun-barrels/#findComment-2978679 Share on other sites More sharing options...
Olgerth Istaarn Posted January 28, 2012 Share Posted January 28, 2012 This is very good! Thank you! Link to comment https://bolterandchainsword.com/topic/246185-how-to-fix-damaged-gun-barrels/#findComment-2979042 Share on other sites More sharing options...
ron Posted January 28, 2012 Author Share Posted January 28, 2012 Glad it helps. It's saved me on more than one occasion from losing a perfectly good bit. As far as rolling out greenstuff, I get it started between my fingers and then roll it the rest of the way between two CD covers. They are smooth and flexible enough that I can put pressure on one as needed to make sure the tube is consistent in diameter. You don't have to be exact with the diameter, just close enough for the repair to work. Link to comment https://bolterandchainsword.com/topic/246185-how-to-fix-damaged-gun-barrels/#findComment-2979133 Share on other sites More sharing options...
