chezzie Posted January 30, 2012 Share Posted January 30, 2012 Greetings brothers! I'm finally returning to 40k after something like 15/16 years away, the last I played was 2nd edition. I've managed to liberate some models from stasis (or parents garage as it's more commonly known) and will be looking for help and advice to build up a reasonable force to fight with. What I have (although I've not sorted the boxes out fully yet): 10xBlood claws 6xLong fangs (although I've no memory of ever buying the 6th model for them but hey) 5xWolf Guard in TDA Ragnar Bjorn Rune priest in TDA. I'm looking for advice on what I'd best add to that to make it reasonably competitive in this edition. From what I've seen it looks like I need a lot of grey hunters, and probably some more LF? Also, does anyone here have any idea what products are good for stripping paint off old models _AND_ available in Germany? Cheers David Link to comment https://bolterandchainsword.com/topic/246374-greetings/ Share on other sites More sharing options...
Arez Posted January 30, 2012 Share Posted January 30, 2012 Welcome to the Fang! have an ale For more units:i say (if you can) get the Space Wolves battleforce and some devastators and magnetize the arms so you can switch the heavy weapons at will.If you get the battleforce you'll have enough bits to "Wolf up" your devastators. as for paint stripper: simple green.its really good and it smells ok.normally you'll need to leave the models in SG for about a day buy since the paint is from 2nd ed you might need to leave it on a little longer. Link to comment https://bolterandchainsword.com/topic/246374-greetings/#findComment-2981169 Share on other sites More sharing options...
chezzie Posted January 30, 2012 Author Share Posted January 30, 2012 Thank you for the Ale, you can never have too much of that! Thanks also for the pointers on units I'll end up with a battle force I think. Wrt simple green, could you let me know which of the products on here http://extradeweb.de/shop/ I need to get hold of? cheers David Link to comment https://bolterandchainsword.com/topic/246374-greetings/#findComment-2981177 Share on other sites More sharing options...
Arez Posted January 30, 2012 Share Posted January 30, 2012 Thank you for the Ale, you can never have too much of that! Thanks also for the pointers on units I'll end up with a battle force I think. Wrt simple green, could you let me know which of the products on here http://extradeweb.de/shop/ I need to get hold of? cheers David sry i dont speak german.the biggest bottle you can get you should.you can use SG to clean up household messes with it to.also you need a container to put some of the simple green with your minies,carefull the simple green does weaken the glue some times causing the minis to come apart Link to comment https://bolterandchainsword.com/topic/246374-greetings/#findComment-2981221 Share on other sites More sharing options...
