Airbrush Questions
Stryke
Hi all,
recently I've thought about getting into airbrushing. I've read some internet articles, but not 100% sure that the compressor I want to get is suitable for miniatures.
Here are its specs:
Power: 1/6 hp
Air Volume ?0.8 CFM
Max. Pressure?60PSI
Certification?CE, GS, ETL, CETL and ROHS
Warranty: 1 yrs
Air tank: 3.0 liters
Weight: 5.2KG
Dimension: 3.9mx1.95mx4.2m
Low Noise 47db
Voltage: 220-240V
It's mainly the power, voltage and PSI that confuses me. From what I gather, it looks suitable, has an airtank for constant pressure, but would like some confirmation.
Thanks in advance
https://bolterandchainsword.com/topic/246889-airbrush-questions/
As long as it has a regulator so you can adjust the psi, it should be fine, and you'll want to dial it down to somewhere between 20-25 psi.
You will also want a moisture trap to keep little droplets of water from getting into the air hose from the compressor.
  • 4 weeks later...
If you're in the US, check these guys:
www.micro-mark.com
I've been dealing with them for over 20 years. GOOD stuff, excellent service.
A small compressor won't set you back too much, they even make them VERY quiet, unlike my first one, which sounded line the tire inflator at the gas station.
I use the Aztek Airbrush, love it, I've got a couple old Pasche units, too, but the Aztek is my go-to. VERY easy to clean, and the double action makes it insanely easy to get some great effects. If you've never used an airbrush before, you'll fine it's a "Golden Bullet" type thing. Once you use it, and get decent with it, you'll wonder why you never used one before. It's like changing from black and white movies to color. Yeah, BIG difference.
Be sure to THIN your paints well. You can always build up layers, and add depth to the color, but if it's too thick, you won't like the results, trust me. better too thin than too thick. :)
