High gloss varnish
Hey folks,
Im just finishing off my chappy and his lucious deep red, gold-flecked power armour (its not canon, but i like the idea of a bold and bright chaplain to really stick out and inspire his troops) is in need of a nice glossy finish to really round it off.
what brands do you use? (Im in the UK if it helps) How to do you apply it - with other products (like the GW purity seal) or some other protective coats?
TJ
https://bolterandchainsword.com/topic/247163-high-gloss-varnish/
  • 3 weeks later...
I'd avoid purity seal if you can, for flat coating Testor's Dullcoat is usually regarded as the best.
The 'best' method for gaming minis:
Gloss the whole thing (use a decent gloss spray / airbrush varnish). Gloss is harder wearing than matt. This layer protects.
Matt the whole thing (use a decent matt spray / airbrush varnish). This takes of the shine. As it wears, you'll notice the gloss showing again - this indicates it's time to touch up the matt.
Gloss what needs to be gloss by hand.
Don't matt spray clear components. This will cause a frosty look, which you don't want. It'll be hit and miss whether glossing over the top removes that effect.
