Lysander's bolter drill + combi weapon shots, combining ?
Hi guys,
I simply wonder if a combi-bolter firing its combi-weapon round count has a bolter for the Bolter Drill ability from Lysander. I know it's not a bolt round but it's still a boltgun that's firing, so what do you guys think ? Now that I think about it there might be a faq about this, anyone ?
thank you!!
Nope.
A combi-weapon is a Bolter with a single-shot version of the "-weapon" attached to it.
The Bolter part of the weapon can be used with Bolter Drill while the single-shot attached "-weapon" part can't unless the attached "-weapon" is also listed under Bolter Drill's compatibility list...which it's not unless it's a Combi-Bolter....and only Chaos has those.
