Hatefires Posted February 17, 2012 Share Posted February 17, 2012 If Typhus tank shocks in a landraider into the middle of 30 orkboys, can he cast nurgles rot? Link to comment Share on other sites More sharing options...
dswanick Posted February 17, 2012 Share Posted February 17, 2012 I would say 'yes'. Nurgle's Rot is a psychic power which does not require Line of Sight and is not a Psychic Shooting Attack, thus "Q: Can a model use a psychic power that is not a Psychic Shooting Attack if it is embarked in a transport vehicle? (p50) A: Yes. If the power requires line of sight, this is still worked out from the vehicle’s fire points (this will count as one model shooting through that fire point if the power is used in the Shooting phase). If the psychic power does not require line of sight and has a range or an area of effect that is normally measured from the model using it, these are measured from the vehicle’s hull, as explained in the Embarking section on page 66.", BRB FAQ seems to apply. Link to comment Share on other sites More sharing options...
Something Wycked Posted February 17, 2012 Share Posted February 17, 2012 EDIT: Ninja'd! Link to comment Share on other sites More sharing options...
Hatefires Posted February 17, 2012 Author Share Posted February 17, 2012 sweet! that sounds NASTY! Link to comment Share on other sites More sharing options...
Morticon Posted February 19, 2012 Share Posted February 19, 2012 Just remember you can't move over 6" and do that trick. Link to comment Share on other sites More sharing options...
Chengar Qordath Posted February 19, 2012 Share Posted February 19, 2012 Just remember you can't move over 6" and do that trick. It's not a shooting attack, so unless I missed something that restriction wouldn't apply. Link to comment Share on other sites More sharing options...
Morticon Posted February 25, 2012 Share Posted February 25, 2012 If thats the case, then yup yup! You're right. Link to comment Share on other sites More sharing options...
