Wulfebane Posted February 27, 2012 Share Posted February 27, 2012 So after reading the new WD, I see they're legitimately giving the option to proxy the new TWL as Harald Deathwolf with the following loadout: Saga of the Wolfkin Frost axe, Storm shield Wolftooth necklace Wolf tail talisman And his TW, Icetooth.... all for a total of 250 points. My concern however, is that Canis comes standard with Saga of the Wolfkin. Since the rules of sagas mean that "no two HQ units can bear the same saga", then with the proposed rules for Harald, you cannot field both units. This makes no sense to me, because Canis is one of Harald's Wolf Guard. So.. should we ignore the proposal of Harald from the WD if we want to field both? If so, which saga is more suitable? Link to comment https://bolterandchainsword.com/topic/247927-harald-deathwolf-counts-as/ Share on other sites More sharing options...
Lord Ragnarok Posted February 27, 2012 Share Posted February 27, 2012 So after reading the new WD, I see they're legitimately giving the option to proxy the new TWL as Harald Deathwolf with the following loadout:Saga of the Wolfkin Frost axe, Storm shield Wolftooth necklace Wolf tail talisman And his TW, Icetooth.... all for a total of 250 points. My concern however, is that Canis comes standard with Saga of the Wolfkin. Since the rules of sagas mean that "no two HQ units can bear the same saga", then with the proposed rules for Harald, you cannot field both units. This makes no sense to me, because Canis is one of Harald's Wolf Guard. So.. should we ignore the proposal of Harald from the WD if we want to field both? If so, which saga is more suitable? Yes, ignore the "proposal". It's just an example. My harald has bear, wolf claw, stormshield and runic armor. Plus a WL fields whatever they want from their amory. Link to comment https://bolterandchainsword.com/topic/247927-harald-deathwolf-counts-as/#findComment-3002558 Share on other sites More sharing options...
Wulfebane Posted February 27, 2012 Author Share Posted February 27, 2012 If I were to field both, I'd give Harald saga of the bear too, but otherwise I kinda like the suggested loadout, hence my confliction. Link to comment https://bolterandchainsword.com/topic/247927-harald-deathwolf-counts-as/#findComment-3002562 Share on other sites More sharing options...
Lord Ragnarok Posted February 27, 2012 Share Posted February 27, 2012 If I were to field both, I'd give Harald saga of the bear too, but otherwise I kinda like the suggested loadout, hence my confliction. Unless special characters are exempt(I can't remember if FAQ'd), I'd think you'd have to field him with a unique saga. Link to comment https://bolterandchainsword.com/topic/247927-harald-deathwolf-counts-as/#findComment-3002563 Share on other sites More sharing options...
eyeslikethunder Posted February 27, 2012 Share Posted February 27, 2012 If I were to field both, I'd give Harald saga of the bear too, but otherwise I kinda like the suggested loadout, hence my confliction. Unless special characters are exempt(I can't remember if FAQ'd), I'd think you'd have to field him with a unique saga. Special characters are exempt p64 Link to comment https://bolterandchainsword.com/topic/247927-harald-deathwolf-counts-as/#findComment-3002566 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted February 27, 2012 Share Posted February 27, 2012 It would be redundant but yes you can give Harald the SOW, for all of the reasons page 64 says so!! I think the suggested kit is quite good, but that kind of model (point sink) need Eternal Warrior more than he need's I5 wolvies... End of Line Link to comment https://bolterandchainsword.com/topic/247927-harald-deathwolf-counts-as/#findComment-3002654 Share on other sites More sharing options...
