mjc Posted March 7, 2012 Share Posted March 7, 2012 Since the requirement for astral aim is that you pass your psychic test and have a fire point, can a ten man purgation squad all fire out of a rhino? Or is it limited to only two models? Link to comment https://bolterandchainsword.com/topic/248559-astral-aim/ Share on other sites More sharing options...
Darkmagi Posted March 7, 2012 Share Posted March 7, 2012 It's still restricted by the number of firepoints the vehicle has so no Astral Aim will only allow 2 models to fire outta the top hach as a rhino only has 2 firepoints Link to comment https://bolterandchainsword.com/topic/248559-astral-aim/#findComment-3009668 Share on other sites More sharing options...
Something Wycked Posted March 7, 2012 Share Posted March 7, 2012 Yep- Astral Aim allows you to ignore line of sight, but it does not allow more firing out of a vehicle than normal. IE, if your Purgators are inside a Land Raider and use Astral Aim, they still can't fire- and only 2 can fire through the Rhino's fire point. ^_^ Link to comment https://bolterandchainsword.com/topic/248559-astral-aim/#findComment-3009726 Share on other sites More sharing options...
T3mpl@r Crusade Posted March 7, 2012 Share Posted March 7, 2012 nothing stopping you from disembarking then firing from behind the rhino though :( Link to comment https://bolterandchainsword.com/topic/248559-astral-aim/#findComment-3009889 Share on other sites More sharing options...
mjc Posted March 8, 2012 Author Share Posted March 8, 2012 Thank you for your responses! Link to comment https://bolterandchainsword.com/topic/248559-astral-aim/#findComment-3010484 Share on other sites More sharing options...
