Blackadders Warlord WIP
Okay so here's the deal, I photo-shopped the image and made a static front view that prints out a model exactly 24 inches tall (On my printer using my editor's print graph I hasten to add). I'm satisfied that this is viable height for a Warlord towering almost 2.5 times the height of a Warhound.
Now that I have the overall height I'll remove the armour and draw in the structural detail.
BTW that's 24 inches to the lower margin of the image because we mustn't forget the foot pads.
http://i.imgur.com/xiYya.jpg
https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/
The whole world! Egad!
Here comes the weekend and I'll be playing to an empty room. I did manage to cut out most of the basic components of both feet and hope to have them glued together this weekend. I used 2.0 mm for the tread base and the rest is 1.0 mm styrene. This beastie is going to consume a lot of plastic but the fabrication will be a lot easier as all the material will be the same so no problem with glue compatibility which is a big plus.
I'll just add this on:
The octagons are the center of the foot pads and are 2.0 mm thick and about 5.0 x 4.5 inches the larger boxes to the right are the front and back toes and the smaller boxes at the extreme left are the side toes. Both sets of these toes will be movable with hinges. The truncated toe pieces to the far right may or mayn't be movable as I haven't planned that far as yet but the disc will tilt side to side and the top surface will house a semicircular gear shape which will allow the entire foot to tilt forward and aft. This should afford a full range of motion to the feet. The semicircle will have a countersunk screw for the axis and a pal nut on the other side to provide the tension to maintain the various poses.
http://i.imgur.com/IPWTEl.jpg
http://i.imgur.com/IPWTE.jpg
http://i.imgur.com/F538Fl.jpg
http://i.imgur.com/F538F.jpg
http://i.imgur.com/EcG2ql.jpg
http://i.imgur.com/EcG2q.jpg
Ambitious? yes;
Possible? most probably,
Crazy? almost certainly.
Ah but if it works Priceless!
Now my dear Blackadder, this was about time you restarted this project ;D But why don't I seem to have stumbled across it on warseer as well ?? :)
The plan sounds (and looks) solid, I'll definitely be following this thread closely :P
I haven't gotten around to all the forums as yet.
I'm trying a different approach and actually planning my work before hand. That in mind I am not the neatest mechanical drawer but it is as true to scale as I need for gov'ment work.
These images should print out 1:1 on 8.5 X 11 paper
This is the size I can up with for a 24 inch Warlord titan. The entire foot will cover a Baneblade tank front tread to exhaust stacks and sponson to sponson which I believe is quite awesome enough considering a Baneblade is as large as my entire house i.e. 30 X 40 feet.
http://i.imgur.com/UtEjfl.jpg
http://i.imgur.com/HiW8ul.jpg
I know I'm gonna reap a lot of flack for ignoring the T'hawk but I'm on a roll with this project and will ride it for all it's worth.
This new enthusiasm is refreshing as working on the T'hawk was becoming tedious but already I'm looking at it with fresh ideas
The toes of Chrysagon coming along nicely an if I have to make the body a few inches taller so be it.
http://i.imgur.com/6o0pkl.jpg
http://i.imgur.com/6o0pk.jpg
http://i.imgur.com/qVyZGl.jpg
http://i.imgur.com/qVyZG.jpg
http://i.imgur.com/0mXpPl.jpg
http://i.imgur.com/0mXpP.jpg
Let's face it, if you needed a break from the thunderhawk, then so be it. It's your project and none of us should feel so self-entitled to seriously hold that against you. You do what you want to, brother. :)
I haven't a clue how much this thing will weigh but I intend to use steel hardware for the joints and reinforced box beam legs. The joints will lock in position with torx screws to disguise the screw head so it won't be flexible like Lucie
Todays effort:
http://i.imgur.com/fElqWl.jpg
http://i.imgur.com/fElqW.jpg
http://i.imgur.com/QmXZll.jpg
http://i.imgur.com/QmXZl.jpg
Plodding along as is my wont I successfully attached the step pyramid style ends of the toes this morning which for the life of me serve no earthly purpose other than aesthetic appeal. (If you like toes.... Jabba )
Mine differ from DS's in that they are slightly wider but the overall design is the same.
Accompanying the feet are some figures to convey scale donated by my son.
http://i.imgur.com/fJVPu.jpg
http://i.imgur.com/fJVPul.jpg
http://i.imgur.com/r5yJw.jpg
http://i.imgur.com/r5yJwl.jpg
I've been working on the disc tilting cylinders. These will allow the disc to tilt side to side while secured to a longitudinal pivot axle yet to be fabricated.
http://i.imgur.com/DZPp9.jpg
http://i.imgur.com/DZPp9l.jpg
http://i.imgur.com/YJ5Zb.jpg
http://i.imgur.com/YJ5Zbl.jpg
http://i.imgur.com/IeSOI.jpg
http://i.imgur.com/IeSOIl.jpg
http://i.imgur.com/NopdI.jpg
http://i.imgur.com/NopdIl.jpg
http://i.imgur.com/orHOg.jpg
http://i.imgur.com/orHOgl.jpg
I appreciate the responses and the subscriptions but just so you know 'The Blackadder' is very prone to mistakes. I spent half a day building the pistons receiving the cylinders on the discs and after forming them and starting to install them found that they were totally unnecessary!
Since they are totally hidden inside the ankle discs whats the point of even installing them? added work more parts to fail; who needs that so eliminated. But all is not lost, they may be useful in another area and if nothing else they keep me humble.
http://i.imgur.com/awVs5.jpg
http://i.imgur.com/awVs5l.jpg
They are shown in the left foreground.
http://i.imgur.com/G6u3t.jpg
http://i.imgur.com/G6u3tl.jpg
So who would know they are even missing :*)
It's extremely gratifying to envision something in your mind's eye and then to duplicate it in some medium. In this case extremely malleable styrene but I can see how real engineers get their rocks off. Granted the days of Isambard Kingdom Brunel and John Scott Russell are pretty much over where an engineer designs and executes an entire construct but I'm sure even today such gratification must still exist.
Case in point, this highly speculative tilting table mechanism for the foot attachment.
I believe I have come up with a viable solution to allow the foot to tilt side to side, be light and strong and also look complex enough to grace a 40K denizen.
http://i.imgur.com/k07P5.jpg
http://i.imgur.com/k07P5l.jpg
Were I to build this for a real vehicle I would enclose the axle within the disc housing so the table doesn't shift side to side as much but then the mechanism would be totally hidden. so this way I have an excuse for the diagonal toes linear actuator system that give enhanced stability during the stepping process and decreases the upper body swaying which is the cause of so much seasickness in some Warhound crew members.
http://i.imgur.com/adYW2.jpg
http://i.imgur.com/adYW2l.jpg
That's my story and I stick with it :P
http://i.imgur.com/X81v7.jpg
http://i.imgur.com/X81v7l.jpg
When I see how much of this system will actually be visible I may fancy it up a bit using some of mxwllmdr's lightened girder and buttress techniques.
The beauty of this construct is it can be disassembled for maintenance, painting and repair.
http://i.imgur.com/jScLR.jpg
http://i.imgur.com/jScLRl.jpg
Wow... really impressive work BlackAdder. I do have one question: why did you choose to base your warlord off the Epic model? Not challaning your choice, I'm just curious why this:
http://i14.photobucket.com/albums/a316/maverike_prime/Warhammer/m1252004_99110307002_EpicWarlordMain_873x627.jpg
over this:
http://i14.photobucket.com/albums/a316/maverike_prime/Warhammer/reference.jpg
Were I to make a Chaos Warlord I would probably go with a Mars pattern the design of which lends itself to the more 'organic' look of Chaos although I do not care for the toes which look weak to me.
If FW were to make a Warlord they might use the Epic Lucius version for the model as I don't recall seeing a Mars pattern in Epic.
