GhostMalone Posted March 18, 2014 Share Posted March 18, 2014 So when can we order? Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3625657 Share on other sites More sharing options...
Jaton666 Posted March 18, 2014 Share Posted March 18, 2014 Amazing work. Keep it up. Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3625714 Share on other sites More sharing options...
Blackadder Posted March 19, 2014 Author Share Posted March 19, 2014 Even at $20,000 US you would have to hold a gun to my head before I'd make another of these................ Altar Alterations: A question for those more knowledgeable than I about 40K Iconology I'm pretty sure the A.D. emblem is correct but the Vampire caped skulls, what are they and are they correct on a Tech Priest Altar? http://i.imgur.com/m2AKvaE.jpg http://i.imgur.com/m2AKvaEl.jpg Hell I'm just going to post all the pictures good and bad and you can sort them out...... http://i.imgur.com/xEDen1b.jpg http://i.imgur.com/xEDen1bl.jpg I'm finally putting some detail into the interior. It was much too stark and empty before. http://i.imgur.com/cM6XOPk.jpg http://i.imgur.com/cM6XOPkl.jpg The Tech-Priest is just there temporary for scale. http://i.imgur.com/Um1gc6q.jpg http://i.imgur.com/Um1gc6ql.jpg I need to work in the College Technical "T" on the wall under the arch and the Sardonic Skull on the other side. Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3626553 Share on other sites More sharing options...
Brother-Librarian Haegl Posted March 19, 2014 Share Posted March 19, 2014 Looks worthy of the Omnissiah's gaze ( as as does just about the entire God-Machine, by the way)! May I humbly suggest some purity seals? I think they would really add to the.. you know... Adeptus Mechanicus feel of the altar. Also, the Tech-Priest looks really at home, looking down into the Strategium. Praise the Machine-Spirit! All glory to the Omnissiah! Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3626661 Share on other sites More sharing options...
MordentHex Posted March 19, 2014 Share Posted March 19, 2014 Even at $20,000 US you would have to hold a gun to my head before I'd make another of these................ Altar Alterations: A question for those more knowledgeable than I about 40K Iconology I'm pretty sure the A.D. emblem is correct but the Vampire caped skulls, what are they and are they correct on a Tech Priest Altar? http://i.imgur.com/m2AKvaE.jpg http://i.imgur.com/m2AKvaEl.jpg Hell I'm just going to post all the pictures good and bad and you can sort them out...... http://i.imgur.com/xEDen1b.jpg http://i.imgur.com/xEDen1bl.jpg I'm finally putting some detail into the interior. It was much too stark and empty before. http://i.imgur.com/cM6XOPk.jpg http://i.imgur.com/cM6XOPkl.jpg The Tech-Priest is just there temporary for scale. http://i.imgur.com/Um1gc6q.jpg http://i.imgur.com/Um1gc6ql.jpg I need to work in the College Technical "T" on the wall under the arch and the Sardonic Skull on the other side. gentalmen, break out your wallets and hand guns! Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3626713 Share on other sites More sharing options...
Blackadder Posted March 19, 2014 Author Share Posted March 19, 2014 More Icons: lotsa conduit cables ducting to come but I needed reinforcement regarding use of proper icons. I won't make the mistake of the CoD backwards Adeptus Mechincus skull again.For your edification two symbols for the side corridors under the Gothic arches: http://i.imgur.com/8Aj1RRH.jpg http://i.imgur.com/8Aj1RRHl.jpg Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3626858 Share on other sites More sharing options...
Blackadder Posted March 20, 2014 Author Share Posted March 20, 2014 Study in Blue Light: Accomplished a bit of work this morning on the interior, railings and buttresses but the big plus to the work is the LED Blue /White lighting. With all the work I put into the College Titanica and the Adeptus Mechanicus skull icon they can barely be seen in the corridor on either side of the Altar nave. I should have included a figure for scale. The right side: http://i.imgur.com/QOJ97Iz.jpg http://i.imgur.com/QOJ97Izl.jpg http://i.imgur.com/WhqYiP8.jpg http://i.imgur.com/WhqYiP8l.jpg Next the Command deck fixtures............. Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3628180 Share on other sites More sharing options...
GhostMalone Posted March 20, 2014 Share Posted March 20, 2014 :O Enough said Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3628195 Share on other sites More sharing options...
Blackadder Posted March 21, 2014 Author Share Posted March 21, 2014 Command Deck Front Bulkhead Redux: I was never satisfied with the future tech look of the front bulkhead that was not in keeping with the battle weary slapdash Gothic interior of the 40K universe. The main hull in my estimation is five decks high starting with the Void Generator housings not shown in the included images due to the fact that they must be removed for visual access of the lower decks. Deck four is the upper Observation gallery and the Adeptus Mechanicus Altar recently updated now with 28 MM scale figure. Deck three which I call the Command deck even though I have been advised that Titans do not require large spaces as they have a minimal crew. http://i.imgur.com/iqNJDfL.jpg http://i.imgur.com/iqNJDfLl.jpg I rationalize Luteus Vexant is a tactical command vehicle that has a Command group of officers. http://i.imgur.com/tXya71T.jpg http://i.imgur.com/tXya71Tl.jpg Below that is the Fusion Reactor, I have no idea what a functioning Fusion Reactor would look like but I imagine it would glow with Cherenkov radiation represented by to central component on deck five. http://i.imgur.com/zB5mFRj.jpg http://i.imgur.com/zB5mFRjl.jpg To either side of the Reactor deck is the triangular shaped cooling grids and coolant recovery system that recirculates the reactor's sodium transfer medium. Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3629413 Share on other sites More sharing options...
Studio Silvernale Posted March 21, 2014 Share Posted March 21, 2014 Regardless, its a thing of beauty =D Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3629440 Share on other sites More sharing options...
Blackadder Posted April 5, 2014 Author Share Posted April 5, 2014 The Void Generators: The top deck houses the Void Generators of which there are four. Since the rear ones cannot be seen unless the model is disassembled I saw no reason to make the two rear generators until I decided to make an interior. So I suppose I need to make two more......... http://i.imgur.com/3qXGeSk.jpg http://i.imgur.com/3qXGeSkl.jpg The generator deck breaks down to five interlocking components are is accessible from either the upper gallery of the Command Deck or from the Hood. The interior of the housings are painted a nice bilious green which seems to glow for some reason......... http://i.imgur.com/Yi1UTmc.jpg http://i.imgur.com/Yi1UTmcl.jpg The forward doors fold down on hinges for maintenance access and removal of the Void Generators........... http://i.imgur.com/GkHcc5p.jpg http://i.imgur.com/GkHcc5pl.jpg The interior walls with roof attached lock in place to the rails on the center main hull ceiling............ http://i.imgur.com/EOD24YW.jpg http://i.imgur.com/EOD24YWl.jpg http://i.imgur.com/jCuvDjQ.jpg http://i.imgur.com/jCuvDjQl.jpg Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3644319 Share on other sites More sharing options...
Squeaky Posted April 5, 2014 Share Posted April 5, 2014 Wow... Always puts a smile on my face coming to this forum :) awesome keep it up :D Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3644408 Share on other sites More sharing options...
Studio Silvernale Posted April 6, 2014 Share Posted April 6, 2014 This thread keeps inspiring me to work on my projects, then I realize I don't have the materials to even try. Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3644470 Share on other sites More sharing options...
Blackadder Posted May 10, 2014 Author Share Posted May 10, 2014 Wrong thread......... Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3682447 Share on other sites More sharing options...
Blackadder Posted August 22, 2014 Author Share Posted August 22, 2014 Shadowsword Interior: Found these images in my copious archives showing the generators for the Volcano Cannon. I much regret not researching this before as the interior would go very well in the Warlord engine room. I at the time coveted with my tongue hanging out the Shadowsword interior which in retrospect, now that I have a bit of scratchbuilding under my belt, would be relatively easy to replicate. http://i.imgur.com/7tnwGHJ.jpg?1 http://i.imgur.com/GJoIlRA.jpg http://i.imgur.com/52V0Wk7.jpg http://i.imgur.com/fxLRJuh.jpg Watch for a major revamp of the Warlord interior coming soon. I had completely omitted the Steam Turbine dynamos GAHHH! I like this one............ http://upload.wikimedia.org/wikipedia/commons/thumb/4/4f/Modern_Steam_Turbine_Generator.jpg/1024px-Modern_Steam_Turbine_Generator.jpg I like this one............ Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3786634 Share on other sites More sharing options...
Blackadder Posted August 26, 2014 Author Share Posted August 26, 2014 The Day The Earth Stood Still: Well maybe not such a world shaking event but never the less something that I would say about 50% of the replies I get are queries when I'm going to paint the Warlord. http://i.imgur.com/UsQnzAo.jpg http://i.imgur.com/UsQnzAol.jpg Well today's the day http://i.imgur.com/yflJ1sb.jpg http://i.imgur.com/yflJ1sbl.jpg Another thing to note is the ankle mechanism is still intact with not a hint of failing either in structure and function so the fears of those that predicted the flexing ankles would fail are pretty much allayed. http://i.imgur.com/s73wBoK.jpg http://i.imgur.com/s73wBoKl.jpg The difference between an engineer and yer average schlub is the schlub usually overbuilds........ I overbuild. So 24 hours of paint drying and I'll be ready to start airbrushing. BTW any painters out there I would appreciate suggestions......REALLY! Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3791298 Share on other sites More sharing options...
Grotsmasha Posted August 27, 2014 Share Posted August 27, 2014 aaawwwww yiisssss Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3791814 Share on other sites More sharing options...
MordentHex Posted August 27, 2014 Share Posted August 27, 2014 still inspiring to look at. your titan is a work of art. so many things that you have done that I would not have to thought of! it really helps me push past that "good enough" phase. Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3792029 Share on other sites More sharing options...
Blackadder Posted August 27, 2014 Author Share Posted August 27, 2014 Can Someone help Me Find My Dog? In the land of the blind the one eyed are kings. Well that philosophy won't do me any good 'cause my dog is blind too. I spent the morning reviewing youtube mech painting and I have come to the conclusion that it seems no one has trod this path before. So I went back to a few Jaro tutorials and decided to work off of the Forgefiend video. His accent is a bit thick but I got AV German Grey and I have to assume it's Model Air Yesterday I forego-ed his recommended acrylic black base coat because I don't have to spend 20 buck$ on tiny vials of black paint when I can paint the entire Warlord for a couple of dollars worth of generic spray can Flat Black. Today I airbrushed German Grey center highlights on the toes and tread patterns and the Ad Mech lcon under the foot pad???? (What Was I Thinking!!!!) http://i.imgur.com/VIplvOj.jpg http://i.imgur.com/VIplvOjl.jpg Okay so the effect I'm going for is that originally this titan was a steely grey-blue and over the millennia the original factory paint and clear coat has worn, burned and rusted off so all that's left is a hint of former colour showing through the accumulated grime, leaking oil and rust. It won't be a Dave Smith camouflage so much as an Earl Scheib $19.95 special (Ask your fathers). Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3792493 Share on other sites More sharing options...
Blackadder Posted September 23, 2014 Author Share Posted September 23, 2014 Department of the Interior: More like the Department of Redundancy Department because I had already done this once but I was never satisfied with the Holo-dome display, first it was too large and the ground looked fake and uninspired so a new attempt was in order and I just returned from my daily 10K walk brimming with new ideas for the cockpit interior as well. The new dome is neater and more compact. First I repaired the head and added the flex conduit, I plan to paint the mechanical sections later today probably black metallic and bronze highlights http://i.imgur.com/Npp5rqC.jpg http://i.imgur.com/Npp5rqCl.jpg Next the interior cockpit forward console (Lower left foreground will be upgraded with wiring and conduit. and be ready to be installed with the twin Moderati pilots seated. I wonder what people that have lives do with their time? Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3816617 Share on other sites More sharing options...
exetus Posted September 23, 2014 Share Posted September 23, 2014 We do a bunch of other useless crap and then log on to B&C to see the updates from creative lunatics like yourself, BA. I thought that was common knowledge?!?! Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3816625 Share on other sites More sharing options...
Blackadder Posted September 23, 2014 Author Share Posted September 23, 2014 The Alien Scene from MP's 'Life of Brian:' http://cdn-media.hollywood.com/images/l/dbe266f47798407eb6cd74e7516daaaec061bf3b.jpg Every time I look at this cockpit I am minded of the aliens in that movie. http://i.imgur.com/ZIESlJD.jpg http://i.imgur.com/ZIESlJDl.jpg The Princep cubical fits well behind the Moderati http://i.imgur.com/G9mMOZc.jpg http://i.imgur.com/G9mMOZcl.jpg I like this view. http://i.imgur.com/zbC3bfy.jpg http://i.imgur.com/zbC3bfyl.jpg Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3816715 Share on other sites More sharing options...
recceboy Posted September 24, 2014 Share Posted September 24, 2014 Once again fantastic work.. Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3816955 Share on other sites More sharing options...
Blackadder Posted September 26, 2014 Author Share Posted September 26, 2014 Thanks, Princeps Are Lifers Anyway: When I was in the service we called career soldiers 'Lifers.' It's not too much of a stretch to make the leap to a 20 year man becoming a permanent fixture in a machine especially if there are the bonuses of virtual 'ahem' amenities. That's why I have no qualms with using a truncated Princep. This wiry bilateral amputee is wedded to the machine god and tied in for the duration. The virtual R&R may be sufficient compensation to commit to such a sacrifice and of course there is free medical. http://i.imgur.com/ned4seG.jpg http://i.imgur.com/ned4seGl.jpg http://i.imgur.com/QH3GN6j.jpg http://i.imgur.com/QH3GN6jl.jpg Anyway it's an interesting deviation. Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3818587 Share on other sites More sharing options...
Blissful Brushes Posted September 26, 2014 Share Posted September 26, 2014 Vis-a-vis the princeps, perhaps you could bend some clear plastic around the outside of it so it's a bit like those nutrient/amniotic tanks that they always harp on about in the books? "Liquid data" and all that. I don't know if I've commented on your threads before, but incase I haven't...as ever, beautiful and the OCD perfectionism is something I can relate to completely! Link to comment https://bolterandchainsword.com/topic/248599-blackadders-warlord-wip/page/27/#findComment-3819016 Share on other sites More sharing options...
