Blackadders Warlord WIP
Thanks for all your work.
BlackAdder, found something on Natfka you might be interested in.
http://3.bp.blogspot.com/-RFh1bacsOWA/VWnKpJSZRhI/AAAAAAAA0VM/VjJY5BWtL9A/s1600/Titans.jpg
Finally a comparison shot and thank you. It's what I have always thought since first seeing the new titan (and pretty much the mistake I made when I did a concept study of my Warlord in scrap plastic paneling):
Written 2010/8/16 when I had just started my Lucius Warlord...........
Whew, were has the summer gone? I had hopes of rendering the basic structure and working on the detail this winter but no such luck plus there are serious errors in scale comparing the the body to the legs and waist. Just to prove the Blackadder is as fallible as they come here is my effort thus far ridiculously out of proportion. The legs are easily 2 to 4 inches too short and the model as it stands is only 19 inches tall. By adding 4 inches to the legs and topping the carapace with the void shield generator housings that should bring it to the goal height of 28 inches.
http://i.imgur.com/zyOR4rAl.jpg
The difference is I recognized my mistake; it looks like FW studied it and copied it, Ha!.
When I build this ( The FW Warlord) I shall lengthen the legs  at least 3 inches..........
I had assumed I would purchase one eventually but I have a lot of projects before then and I keep getting disappoint hints that everything is too small[ ahem! meaning the cockpit/visor assembly and the Main cannon of course. I have a friend who is going to furnish detailed measurements when he returns from vacation.
You should just send forgeworld a resume and become a sculptor! At least then well know thing will be properly scaled for the big stuff :)
I'll be very interested to see those numbers.  Thank you very much!
Some people seem less than happy that I am less than happy with the scale of the new official Warlord titan but the main criticism I received when build my model was, "It's 'way too small." Now it appears,"It's 'way too large" (A complaint I regrettably concede has not been forthcoming in other areas.)
Had FW offered their diminutive M.B.Titan before I built mine I would have gladly built mine accordingly instead of possessing the outsized 500 pound gorilla in the room as would the case seem at present. Ha!
E.L.M.E.R. Gantry:
I took a week of to arrange my work area as things were getting pretty messy with all the projects going at once and I was rapidly running out of work space.
I did manage to cut out the intermediate deck of the E.L.M.E.R. Gantry (EXTRAVEHICULAR LEGIOS MECHANICUS EVALUATION & REPAIR Gantry) to receive the fully assembled Warlord; the gantry takes up all my paint work table space and hopefully when finished will provide both a display diorama fitting for such a construct plus a safe container to house the model in in one piece rather than separate the hull from the legs to prevent toppling as I do now.
http://i.imgur.com/atyfd1n.jpg
http://i.imgur.com/atyfd1nl.jpg
Something seems wrong with the focus on my camera but in the images presented ther is the new beginning of the command deck hologram tactical display plus a Space Marine for scale.
http://i.imgur.com/zaIi3OR.jpg
http://i.imgur.com/zaIi3ORl.jpg
  • 3 weeks later...
Thank you; I appreciate that critique.
The following is in answer to a post on another forum but it pretty well delineates my intentions regarding this construction:
Some Thoughts on My Warlord Titan Hangar:
Granted in it's initial state being fresh (Ahem; figuratively speaking) out of the recycling bin it is little more than a set of cheap plastic shelves but yes I am going to add beam mounted  e.g.
Allegheny_Ludlum_Steel_Corp_Scrap_Piles.
four way overhead track traveling cranes with electromagnetic lifting heads (Rare earth magnets) on all four levels for moving heavy components.
 and:
http://www.aplecgroup.com/INGLES/imagenes/fotos/Minelli%20web/Electroim%E1n%20(6).jpg
Plus catwalks aplenty, recessed tracks for small cranes, and hangar support vehicles, oodles of suitable pseudo-religious 40K artifacts, tech priest enclaves, and I'm hoping to find 28 MM ground maintenance personnel and a few Sentinel Heavy Lifters to dress up the hangar.
A journey of a thousand miles begins with a single step.............
Don't forget, my Lucius Warlord was once just so many styrene sheets and recycled bottlecaps... Ha!
My goal is to make a stable display stand/diorama for my titan to be stored in when not in play as while it does have the capability of standing unaided for days on end it has toppled over on occasion incurring time consuming repairs. I'd prefer not to have to be continually rebuilding it. Plus this will make a handy storage/display area for my other two titans as well.
Thanks for the replies. I wanted to make a display that would also protect the model and be a bit different from the usual battlefield motif. Being a mechanic for most of my life what could be more natural than a hangar/gantry with support personnel and vehicles prepping the monster for battle and repairing damage. I have to admit I drew inspiration from the game SM Invictus; what a pity Invictus didn't make his way out of the hangar........ That would have been an awesome sight as the camera drew back from him standing in the doorway.
An Interesting Image:
Found this comparison image on the internet and superimposed the skulls which are virtually the same size.
http://i.imgur.com/9lAmRIm.jpg
One might extrapolate based on this image that the Lucius Warlord stands taller than the Mars by a considerable amount.
I did a rough mock-up based on the dimensions of the 40K Lucius-pattern that I'm working on, using the Reaver as my yardstick.  I think that ours are comparable in height.
http://i.imgur.com/1pgxxbUl.png
That's almost spot-on!  It would seem that everyone was correct in their selection of scales.
I really like the re-purposed shelving that you're using as the base structure to build on. With all of the ribbing it looks great at that scale with virtually no effort, and it will save some time once you get building. It just goes to show that scale is everything, and even mundane items can become amazing models with a little creativity. I'm constantly looking at everyday objects for their modeling and conversion potential. So awesome.
 If that is a correct scaling of the FW warlord to the this his Lucius than sorry but the FW model is still a bit small on scale. the top armor on the Mars pattern should come up to the Chin of the Lucius. It look so unimpressive next to the Lucius ascetically in my eyes.  I would rather scratch build mine than buy this downsized, yet stunning model. The scaling is just to off putting for me to really take it serious. It looks like a super Knight.
Yes. Blackadder should work for FW so that they can get their super heavy vehicle scaling right for once. I mean if your going to go big, go big or go home right?
Well, I did say "almost spot-on". It's a lot closer to the original Epic scaling than I thought, and shows that neither 40k versions are seriously incorrect. FW was true to the pattern they chose, as was Blackadder - the slight difference is well within the margin of expected variation, compared to many other Epic-to-40K comparisons.
Although I'm definitely a dedicated Lucius fanboy, I do have to be fair. The new Mars pattern Warlord is incredibly faithful to the original design, possibly more so than the new Knights:
http://i.imgur.com/0cP7OdQl.png
I'd say that everyone is doing an excellent job, and especially Blackadder.  Absolutely fantastic work!
