mjc Posted March 8, 2012 Share Posted March 8, 2012 Does Karamazov's special rule "Dread Reputation" allow units he joins to automatically pass or fail morale/pinning checks or does it just allow them to re-roll all failed morale/pinning tests? Link to comment https://bolterandchainsword.com/topic/248634-karamazovs-dread-reputation/ Share on other sites More sharing options...
mjc Posted March 9, 2012 Author Share Posted March 9, 2012 The more I look at the rule,the more I feel it means the following: Karamazov himself while not part of a unit may choose to pass or fail any morale/pinning test. If he joins a unit they will get to re-role a failed test. Interestingly, he does not have stubborn. Let me know your thoughts. Also how are people using him within their armies? If at all. Link to comment https://bolterandchainsword.com/topic/248634-karamazovs-dread-reputation/#findComment-3011848 Share on other sites More sharing options...
Drachnon Posted March 9, 2012 Share Posted March 9, 2012 I'm not sure if anyone is using him. However I believe he can choose to pass a ld test even if he joined a unit. IIRC leadership tests are made using model with the highest LD which thanks to his LD 10 will usually be Karamazov. Link to comment https://bolterandchainsword.com/topic/248634-karamazovs-dread-reputation/#findComment-3011921 Share on other sites More sharing options...
Tankred Posted March 10, 2012 Share Posted March 10, 2012 Fact is: If he has´nt joined a unit, he can pass or fail that test, any friendly unit within 12" may reroll failed motivation and pinning tests. Now we have to look at the rulebook, how it works, if he joins a unit. But, as "stubborn" is transferred to the unit, if someone with stubborn joines the unit, I think the unit will also pass or faill any test, if joined by Karamasov As he is no OM Inquisitor, an I don´t like the modell, I´m not fielding him, I field only OM Inquisitors, at least, when I field one, most of the time I only field GK. Link to comment https://bolterandchainsword.com/topic/248634-karamazovs-dread-reputation/#findComment-3012020 Share on other sites More sharing options...
