Chooser of the slain and Runic armor
Jaredbleu
How do i do a chooser of the slain marker?
Do i have to do anything special to my models for them to have runic armor? paint or piecewise?
I hope this doesn't come off rude but what does your codex tell you? have a look at the search function on here and get some ideas going from other people's work. Just as long as you follow what it states in the codec and people wouldn't have too much issues with it.
I use a servo skull with a wolf tale pinned to it and I cut the bird off the old rune priest model and pinned it to a small tree stump (both on small bases).
There is an armour front and legs in the wolf pack set that seems to work the best. I used it on my first wolf lord model (since then I use him as a priest when I do field it) but as far as my experiance has been as long as you tell your opponent it has never been an issue with my too real rune priests in power armour.
Runic armor is anything from runes carved into the armor or painted on, etc. Several bits from the SW kit have carved runes, and the decal sheet has runes too... but Runic armor does not have to be WYSIWYG.
Choosers are left to your imagination. Think wizard familiars or d&d henchmen/minions in a 40k setting. They should not be on a base larger than the 25mm size, as that is the smallest base a rune priest can fit on.
  • 2 weeks later...
