My Crimson Fists company project
I've used the Flesh Tearer shoulder pads and they're a little smaller then regular plastic ones which I think is the same for all the metal pads..
However, If you put your models in exciting poses and stuff you don't notice. I only imagine you'd notice if you had the 2 pads symmetrical on the model to see it.
Hope that helps
I've used a lot of the metal pads - both the old ones and the newer ones - without any problems.
So long as you take time in cleaning them of excess metal, including a little reaming out of the inside, they will fit the SM arms just fine.
As CMK states, the older ones are slightly smaller than the current/plastic ones, but this really does not appear obvious once painted up. I've used some of the IF/CF ones with the Tactical ones and they work great.
