Thantoes Posted March 12, 2012 Share Posted March 12, 2012 Very random but has anyone had an issue with Liche Purple bleeding when applying a matt varnish. I am having this issue at the moment. I am using Windsor and Newton Matt Varnish and its causing my purple to bleed. Only the purple mind. The other colours are fine. Boltgun metal, shining gold, blazing orange etc are not bleeding. Any thoughts? Link to comment https://bolterandchainsword.com/topic/248892-warlock-purple-bleeding/ Share on other sites More sharing options...
winterdyne Posted March 12, 2012 Share Posted March 12, 2012 How long did you leave it to cure before varnishing? Had this issue with red inks in the past, REALLY had to give those a long while to fully dry. What release of the paint too. I have some very old warlock purple. Could potentially be something chemical with the varnish too - try a different varnish (put a spot of gloss on before the matt) to seal on the purple and see if that makes a difference. Link to comment https://bolterandchainsword.com/topic/248892-warlock-purple-bleeding/#findComment-3014209 Share on other sites More sharing options...
