Marik Posted March 13, 2012 Share Posted March 13, 2012 So I have noticed that the Vallejo Reds seem to be much thinner than any of their other colors. Does anyone else find this to be the case? It seems no matter how long I shake it I just can not get it to come out in any consitiancy thinker than an ink and it is really starting to annoying me because it feels like there is a solid clump in there yet I can't get the damn thing to break up even stabbing it with a toothpick hasn't yield any real results. So any advice is much appreciated. Link to comment https://bolterandchainsword.com/topic/248953-vallejo-red-help/ Share on other sites More sharing options...
Redfinger Posted March 14, 2012 Share Posted March 14, 2012 I use Vallejo paints and I have seen the same issues....The problem is with red, is that it is such a saturated pigment base that there is not a lot of binder in the paint, resulting in a more watery like texture. Thin coats are the way to go. I have found that Vallejo Flat Red to perform much better than Vallejo Red, if you are looking for a darker shade, try mixing a 50/50 mix of Vallejo Flat Red and Vallejo Black Red, that should give you a color similar to Vallejo Red. Ashton Link to comment https://bolterandchainsword.com/topic/248953-vallejo-red-help/#findComment-3015831 Share on other sites More sharing options...
BoogeyMan^ Posted March 15, 2012 Share Posted March 15, 2012 I use Model Color Flat Red 957. I didn't notice any issues, actually. Consistency if the same as my other Model/Game color paints. Haven't tried other reds, though, but Flat Red performs very well for me. Link to comment https://bolterandchainsword.com/topic/248953-vallejo-red-help/#findComment-3016534 Share on other sites More sharing options...
JaM_TW Posted March 15, 2012 Share Posted March 15, 2012 Flat red is the one you want, the ' deeper' red(s) are too thin IMHO. Will check numers at home if needed. I use the model colours btw. (VMC). Link to comment https://bolterandchainsword.com/topic/248953-vallejo-red-help/#findComment-3016598 Share on other sites More sharing options...
