Custom Warhound Titan
Brother Sivak
i have played Black Templars for years on and off.i decided my army needs alittle more firepower.this is my first time building this.i started this 3 days ago and hope within a month to be done building.any ideas to help build this titan would be great.
http://i1244.photobucket.com/albums/gg570/sivak79/titan1.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan2.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan3.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan4.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan5.jpg
https://bolterandchainsword.com/topic/249352-custom-warhound-titan/
  • 2 weeks later...
some more work done this past week.i hope to get the head done by this weekend.
http://i1244.photobucket.com/albums/gg570/sivak79/titan7.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan6.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan9.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan8.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan10.jpg
That's fantastic.
I've been experimenting and making my own templates by guestimating everything. Seeing this puts my efforts to shame, well done.
Something tells me I'm going to be following those templates myself rather than continue with my design.
Can't wait for you're next update.
Using foam core, how did you accommodate for the fold lines? Did you have to cut the foam core out to fit or did you have to reduce the overall size of the squares by the thickness of the foam core used to maintain the measurements when you assembled the pieces?
Also noticed in the "rounded" section of the main body part, do you need to fill in the gaps or is it supposed to be like armour plates attached?
Hrmmm...I'd like to see a close combat Warhound myself. Perhaps I shall when all my other projects/armies are done >_>
I'd be carving sigils of purity into it's very framework! Blessing it with armament and pieces from my first Templar models! It would be glorious! o.O
But I wouldn't get my offcial certificate of Titanness. Damn Imperial Bureucracy.
wow that i looking fantastic! Ill have to start on my own after I get school out of the way an move. Im very excited to see the end of this. Perhaps when your done, could you provide a lit of materials for the little details and the structure? doesnt have to be in depth at all, but I would greatly appreciate it :D
merc3065...Since this was my first time building a titan i decided to go with foam board.its easy for me to mold and cut but did notice it was off from design.
-Toes did come out more box end then slightly pointed.i fixed that problem but havent placed them on yet.
-Alot of molding because foam board is 1/8 thicker so yes their was extra pieces not needed.
-gaps was filled with hot glue then slowly cut of to even out.i will even as much as i can then prime it grey first to ook for any extra gaps.
-Head is being made out of plastic card because foam will be alot harder
after i build this one i will build one out of plastic card or move to building a warlord out of foam board.warlord will have working torso and weapon movement from my spare rc car servos.if anyone has any ideas on the weapons to help make them.i think foam ones will look like poop ir might need to visit local hobby shop to get supplies.
I do concur... :cuss amazing! I'd like to see the cost/build comparisons between scratch built and FW. All I know is, I'd LOVE to have me one of those stomping around the board! I could care less if it's scratch built or not...can't wait to see it completed. It's coming along quite nicely.
Have to ask though, what's it's background fluff for being deployed with a Crusade? Especially with Templarness built in.
It is likely to be similar to the lightning squadron that gained the honor of displaying the cross, though after helsreach the twmplars would not exactly be in the admechs goodbooks.
http://i1244.photobucket.com/albums/gg570/sivak79/titan11.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan12.jpg
http://i1244.photobucket.com/albums/gg570/sivak79/titan13.jpg
been busy at work so only had time to finish the head and started on building housing for weapons.im going to fill up any cracks and open gaps then prime it to look for any more gaps.
