tactic against grey knights
Matt D
so this is my list.
i like it a lot. i like to be diverse. i think its one of the great things about space wolves. most of it is pretty self explanatory except maybe the WG. they breakdown like this: fist/c-melta and grey hunters w/melta in rhino, fist/c-flamer and blood claws w/flamer in razorback, TDA/CML and grey hunters w/plasma in drop pod, TDA, fist/c-melta and grey hunters w/melta in LR redeemer with the RP. the last three are in TDA w/1 PF, 1 WC, 1 PW and all have c-plasma in a drop pod.
this is a fun, hard hitting list. my only real problem come up with grey knights and there ability to screw with my drop pods. if you land within 12 inches they get to pas a psychic test to make you roll for mishap. i have lost many a pod to this.should i be less aggressive in placing them or is there something else i can do to combat this?. would love some advice brothers!
https://bolterandchainsword.com/topic/249387-tactic-against-grey-knights/
I have very little experience against GK's, however, I do know that it's been talked about here; the consensus was to use plenty of AP2 weapons as that hurts the GK saves the most, denying them their best save. There's no reason to change your list, just keep in mind that as far as this list goes, if it is how you like, that LRR and your Plazorback (Las/Plas) will be potential game changers, due to the above line. This will also make them targets.
you can always deploy the units on foot, and let the pods come down empty...
I agree with this, I'd deploy empty pods and use them to block the greay knights cutting down on their mobility.
I think the important thing to keep in mind with GK is yes they have fancy psychic powers and force weapons all round but at the end of the day they are still marines and you need to keep that mindset. Take away their vehicles and then shoot them until they are gone.
Think of the game as a war of attrition, you want to look for the thing thats scariest at that time and hit it until its no longer scary. Your drop pods can allow you to deal with that because it allows you to slow them down so you can concentrate on one or 2 squads.
Plenty of ap 2 or mass unload charge from Landraiders.
I've noticed that grey knights are one of the strongest armies out there against space wolves. Rock to our scissors sort of thing.
Forceweapons... trumps t-wolf cavalry
anyone with hammerhand w/ halberds... trumps any and all of our cc units
stormbolters... with or without psybolts they pump out a ton of firepower across the board that is hard to sustain
psycannons... the ultimate solution to light AND heavy vehicles (if you do the math the psycannon is the nastiest weapon against a landraider at 24 inches that any space marine army has access to, its numbers are considerably better than lascannon, minus the range deficit).
warp quake... anti drop pod
Interceptors... *shunt* "surprise longfangs, suck my psybolts!"
Also, a runeprist's runic weapon is lackluster against Gk compared to a psychic hood, which further hurts SW.
To fight grey knights you have to build a list that is based around fighting them, at the detriment of other facets of your list. I too play drop pods (3), I too have used plazorbacks, t-wolves, etc, and I've found that it all lacks against this one opponent more so than any other. Grey knights are a list that EXCELS at killing ELITE armies, because frankly they are elitier. I build a list that I know will be strong against the majority of armies out there, then I pray that I don't draw the GK lists playing in the tournament, then IF I do, I pray they are inexperienced, etc, and that I can weasel my way to a win with my list that is good for most things and bad for Gk.
To build a list to kill GK armies would mean using a shooting list that aims to get within 12 inches and unleash hell, but not to assault them. In H2H GK will win, but at 12 inches a bolter and a storm bolter are effectively the same gun. My anti GK list would include lots of 10 man Grey Hunter squads in Rhino's with melta/plasma or plasma/plasma and no special CC goodies. I would go heavy on long fangs. A rune priest would be a requirement, even if its not as good as having a P.Hood. I would run a shooty RP, living lighting/MH is a good combo, add a chooser and he can put down some solid firepower while sitting with the LFangs and protecting them if need be. It will do ok against some stuff but you don't have all the "cool" units. I like my cool units, so I just try to make what I run work when forced into that situation.
If you have a desire to be the nemesis of Gk's though, play a plasma rich guard army and call it a day ;-)
Sly doesn't deepstrike (technically), he doesn't scatter, and he has one serious hard on for dropping a demo-charge on top of that phat paladin unit. I know its not space marines/space wolves but it is the best solution I've come up with yet to those pesky GK.
just wanted to say thanks for all the replies! the 2 big changes i am going to try i think are 2 rune priests instead of 1 and deploying the drop pods empty while using them as cover and creating fire lanes. anything else you guys can think of to mitigate warp quake?
Rune trumps Hood where both are Ld 10 vs Ld 10 (ICs, Vehicles, Dreads). Where the user of a Hood is Ld 10 and a GK unit is 9, the Hood is better as it is more likely to stop the power being cast then.
I find IC's, dread's and vehicles quite common in GK lists. Actually i think have seen more of these in most lists I have played than ld9 units
58% or 42 % against 50 % I dont see a big difference and i really hate fortitude
The best thing to do against GK is to hide your RP, but put him in range to (potentially) nullify Fortitude. Beyond that, it's mostly the same as fighting other Marines: dump them out of transports then shoot the heck out of them. If you're worried about Paladins, try fitting more Lascannons into your list. A guy in my group plays Draigowing, and I now bring 6 Lascannons in my list. He gets really nervous about it since they're AP2 and Instant Death the Paladins.
I don't think Assaulting GK is entirely out of the question, especially GK in PA. Just make sure you bring overwhelming force - more than 2x GH to GK would be ideal. Try to isolate and overwhelm individual GK. Because of the points, you can win a war of attrition if you are trading models close to 1 for 1 with him. If you are seeing "Psyfilemen" Dreds in the backfield, consider Wolf Scouts. They're our best weapon against them.
