assault marine weapon upgrades
ademiri
Gamesworkshop sells sets of 5 melters via online store if that helps <_< Otherwise checking out bits shops online may be an option although they rarely have melters in stock.
A link for the gamesworkshop melters: http://www.games-workshop.com/gws/catalog/...dId=prod1400031
I've got a ton of the metal meltas from GW and they're fine, but are heavy and need weighting. Also, it's better to cut the hand off the gun and glue/pin it to the hand that's attached to the arm. Otherwise you can have a hand that doesn't match the other one.
And many of the assault arms (like the 90 degree bent elbow pistol arms) don't fit those melta guns so well because of the brace thing at the back of the gun. So I've been cutting that off too and it doesn't look too bad.
