GS Fist Icon -
Stage One: (Sorry, no picture atm!)
Start by sculpting a small flat rectangle, this will form the base of the palm fingers of your fists. Try to keep the shape to less than 1mm depth, ideally you want it thin enough for you to be able to highlight it, which requires a step of at least about half a millimetre. Ensure you leave plenty of space below the rectangle for the rest of the gauntlet. Once you're happy with the shape, put the mini down for 24 hours. The trick to keeping this simple is to let each stage cure completely before moving onto the next one, that way you can't ruin any of your work through accidents with your sculpting tool!
Stage Two:
http://s3.amazonaws.com/data.tumblr.com/tumblr_m1ia088AWr1qd9z3no1_1280.jpg
Now your rectangle is dry, you want to create a teardrop shape which overlays the rectangle. Use your sculpting tools to straighten up the edges and create sharper points to form the gauntlet shape. Once you're happy with the shape lightly depress the GS either side of the centre of the teardrop, this give the gauntlet some definition to highlight later. Again, leave the GS to cure overnight.
Stage Three:
http://s3.amazonaws.com/data.tumblr.com/tumblr_m1k2nlUS8p1qd9z3no1_1280.jpg
Create a small sausage of flattened GS at the top of the fist.
http://s3.amazonaws.com/data.tumblr.com/tumblr_m1k2uz0CES1qd9z3no1_1280.jpg
Now use your sculpting tool to press a vertical line down halfway across the sausage horizontally. Then repeat in the middle of the two remaining sausages to create the fingers. Now leave the GS to cure for another 24 hours.
:lol:
As you can see the fingers haven't gone perfectly on this one, but it'll still look ok when it's done!
Final stage!
http://s3.amazonaws.com/data.tumblr.com/tumblr_m1m4ddsfXj1qd9z3no1_1280.jpg
Add a sausage of putty the same size as before in the gap between the fingers and wrist. Press down on the sausage in a diagonal line to create the thumb.
Leave to cure for 24 hours.
Happy days.
WotF
https://bolterandchainsword.com/topic/249804-how-to-gs-imperial-fist-icons/
Register a new account
Sign in
